Home » Eclipse Projects » Rich Client Platform (RCP) » Error:Transfer RCP project with Multi Page editor
Error:Transfer RCP project with Multi Page editor [message #696268] Wed, 13 July 2011 11:38 Go to next message
shankhs  is currently offline shankhs
I have created a multi-page editor RCP project with extension points. I wanted to share this project with my friend but when I export the project ( right-click the project, select export , select archive file) and import it back again on a different system the multi-page editor is not recognized so the GUI doesn't have any editor.
Can you please help me with solving the issue of getting the editor up?
I am fairly new to RCP dev.
(no subject) [message #703798 is a reply to message #696268] Wed, 27 July 2011 19:04 Go to previous message
Wim Jongman is currently offline Wim Jongman
Hi Shankhs,
Please explain better. Are you making a plugin? If so you have to export as
deployable plugin instead of jar and then put it in the dropins folder.
Wim
> Thanks
Previous Topic:Eclipse IDE save undo redo menu entries stay greyed out
Next Topic:Overriding the value of an attribute in plugin.xml
Current Time: Mon May 20 04:30:27 EDT 2013
Powered by FUDForum. Page generated in 0.11225 seconds
