| Installing an existing plug-in [message #696025] |
Wed, 13 July 2011 01:50  |
MarcoGT Messages: 77 Registered: May 2011 |
Member |
I am working on extending the default Eclipse XML Editor adding some features to org.eclipse.wst.xml.ui plug-in.
When I run it from Eclipse using "Run as Eclipse Application" it works fine and I have all features I have implemented.
So I tried to install it putting the exported JAR file in the "dropins" folder.
Plug-in name is: org.eclipse.wst.xml.ui_v2.0.0XYZ where XYZ is the plug-in qualifier; the default plug-in name is org.eclipse.wst.xml.ui_v1.2.2ABC.
I read that if Eclipse finds two plug-ins having the same name it should load the newer one but in my case it always loads the default one...why?
Marco
FUDForum. Page generated in 0.03397 seconds
