Home » Eclipse Projects » BIRT » Problem with Empty Rows
Problem with Empty Rows [message #693434] Wed, 06 July 2011 09:21 Go to next message
vijay kumar is currently offline vijay kumar
I am using cross tab to display my result. my resilt returns 6 rows. in that one row is having value for for one field and remaing fileds are null. I have attached the screen shots of what am i doing.
some one help me. thank you in advance
Thank you
vijay Kumar Bolisetti
Re: Problem with Empty Rows [message #693704 is a reply to message #693434] Wed, 06 July 2011 22:37 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Is account year nested in the cube design? If so can you set it as a
dimension on its own?
Jason
On 7/6/2011 9:21 AM, vijay kumar wrote:
> Thank you
Jason Weathersby
BIRT Exchange
Re: Problem with Empty Rows [message #693709 is a reply to message #693704] Wed, 06 July 2011 23:51 Go to previous messageGo to next message
Thanks Json,
I have done that purposefully so that i can display for each year values in Pivot style. i have observed one thing either any one value for coumn or row it is diaplying.
one way i thought is to place the dummy scope value.
Thank you
Re: Problem with Empty Rows [message #695864 is a reply to message #693709] Tue, 12 July 2011 13:06 Go to previous message
Michael Williams is currently offline Michael Williams
What do you want your output to look like? If you have a value in one column of a row, but not for the others, it's going to be blank. If you don't want it to just be blank, then in the text box in the 4th screenshot in your DOC file, put what you want it to show when there are "null" values.
Michael
BIRT Evangelist on
http://www.birt-exchange.org
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Multiple questions on BIRT engine
Next Topic:Unwanted page breaks in PDF output
Current Time: Sun May 19 07:09:44 EDT 2013
Powered by FUDForum. Page generated in 0.01757 seconds
