Home » Eclipse Projects » BIRT » BIRT crashes on Mac OS X Snow Leopard
| BIRT crashes on Mac OS X Snow Leopard [message #693565] |
Wed, 06 July 2011 14:53  |
diddy Messages: 6 Registered: July 2011 |
Junior Member |
I just downloaded the 64-bit Cocoa version.
Eclipse BIRT keeps on crashing when adding certain report elements. Does somebody know how to fix this? I get this error message:
[code]
Process: eclipse [1977]
Path: /Applications/Dev/eclipse/Eclipse.app/Contents/MacOS/eclipse
Identifier: org.eclipse.eclipse
Version: 3.7 (3.7)
Code Type: X86-64 (Native)
Parent Process: launchd [282]
Date/Time: 2011-07-06 19:43:30.468 +0100
OS Version: Mac OS X 10.6.8 (10K540)
Report Version: 6
Interval Since Last Report: 200045 sec
Crashes Since Last Report: 4
Per-App Interval Since Last Report: 1111 sec
Per-App Crashes Since Last Report: 2
Anonymous UUID: 4257B873-7963-4CF7-9BB8-BD1003648BA4
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: 0x000000000000000d, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=7fff82c67a62
Java VM: Java HotSpot(TM) 64-Bit Server VM (20.1-b02-384 mixed mode macosx-amd64)
Current thread (115001000): JavaThread "main" [_thread_in_native, id=1888873664, stack(7fff5f400000,7fff5fc00000)]
Stack: [7fff5f400000,7fff5fc00000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.swt.internal.cocoa.OS.objc_msgSend(JJJLorg/eclipse/swt/internal/cocoa/NSPoint;Lorg/eclipse/swt/internal/cocoa/NSSize;JJJZ)J+0
j org.eclipse.swt.internal.cocoa.NSView.dragImage(Lorg/eclipse/swt/internal/cocoa/NSImage;Lorg/eclipse/swt/internal/cocoa/NSPoint;Lorg/eclipse/swt/internal/cocoa/NSSize;Lorg/eclipse/swt/internal/cocoa/NSEvent;Lorg/eclipse/swt/internal/cocoa/NSPasteboard;Lorg/eclipse/swt/internal/cocoa/id;Z)V+65
j org.eclipse.swt.dnd.DragSource.drag(Lorg/eclipse/swt/widgets/Event;)V+310
j org.eclipse.swt.dnd.DragSource$1.handleEvent(Lorg/eclipse/swt/widgets/Event;)V+81
J org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/swt/widgets/Event;)V
j org.eclipse.swt.widgets.Display.sendEvent(Lorg/eclipse/swt/widgets/EventTable;Lorg/eclipse/swt/widgets/Event;)V+24
j org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/widgets/Event;)V+9
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;Z)V+73
J org.eclipse.swt.widgets.Display.runDeferredEvents()Z
J org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V
j org.eclipse.ui.internal.Workbench.runUI()I+555
j org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j org.eclipse.ui.internal.Workbench$7.run()V+55
j org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+108
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v ~StubRoutines::call_stub
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
Java Threads: ( => current thread )
11d019000 JavaThread "Chart live preview thread" [_thread_blocked, id=744452096, stack(12c4f7000,12c5f7000)]
1213fa000 JavaThread "Worker-16" [_thread_blocked, id=743391232, stack(12c3f4000,12c4f4000)]
1149a9000 JavaThread "536691203@qtp-1704392431-12" [_thread_blocked, id=718303232, stack(12ac07000,12ad07000)]
121345000 JavaThread "Worker-15" [_thread_blocked, id=682639360, stack(128a04000,128b04000)]
11d096800 JavaThread "Worker-13" [_thread_blocked, id=681578496, stack(128901000,128a01000)]
12108d000 JavaThread "derby.rawStoreDaemon" daemon [_thread_blocked, id=719659008, stack(12ad52000,12ae52000)]
11dac8800 JavaThread "Timer-11" daemon [_thread_blocked, id=717242368, stack(12ab04000,12ac04000)]
11df7a800 JavaThread "derby.antiGC" daemon [_thread_blocked, id=716181504, stack(12aa01000,12ab01000)]
11d85f800 JavaThread "908505087@qtp-1704392431-6" [_thread_blocked, id=685821952, stack(128d0d000,128e0d000)]
12108e000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=661655552, stack(127601000,127701000)]
11494c800 JavaThread "AWT-Shutdown" [_thread_blocked, id=658558976, stack(12730d000,12740d000)]
11df90800 JavaThread "Timer-0" daemon [_thread_blocked, id=648028160, stack(126902000,126a02000)]
11df8e800 JavaThread "703254587@qtp-1704392431-1 - Acceptor0 SelectChannelConnector@127.0.0.1:52675" [_thread_in_native, id=634937344, stack(125c86000,125d86000)]
11df2c800 JavaThread "JavaScript indexing" daemon [_thread_blocked, id=572583936, stack(12210f000,12220f000)]
114cad800 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=632332288, stack(125a0a000,125b0a000)]
11daee800 JavaThread "MultiThreadedHttpConnectionManager cleanup" daemon [_thread_blocked, id=630198272, stack(125801000,125901000)]
11dd5d800 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=615092224, stack(124999000,124a99000)]
11559c000 JavaThread "Worker-3" [_thread_blocked, id=577449984, stack(1225b3000,1226b3000)]
11dd82800 JavaThread "Java indexing" daemon [_thread_blocked, id=614031360, stack(124896000,124996000)]
11da22800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=549822464, stack(120b5a000,120c5a000)]
11d149000 JavaThread "Worker-JM" [_thread_blocked, id=573972480, stack(122262000,122362000)]
11d286800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=596643840, stack(123801000,123901000)]
11d905800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=568381440, stack(121d0d000,121e0d000)]
11d16a000 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=552529920, stack(120def000,120eef000)]
11482e000 JavaThread "State Data Manager" daemon [_thread_blocked, id=546344960, stack(120809000,120909000)]
11523f000 JavaThread "Framework Active Thread" [_thread_blocked, id=544649216, stack(12066b000,12076b000)]
11482f800 JavaThread "Poller SunPKCS11-Darwin" daemon [_thread_blocked, id=511336448, stack(11e6a6000,11e7a6000)]
11d011800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=508612608, stack(11e40d000,11e50d000)]
11d010800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=507551744, stack(11e30a000,11e40a000)]
11d010000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=506490880, stack(11e207000,11e307000)]
11d00f000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=505430016, stack(11e104000,11e204000)]
11d804000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=504369152, stack(11e001000,11e101000)]
114805800 JavaThread "Finalizer" daemon [_thread_blocked, id=484458496, stack(11cd04000,11ce04000)]
114804800 JavaThread "Reference Handler" daemon [_thread_blocked, id=483397632, stack(11cc01000,11cd01000)]
=>115001000 JavaThread "main" [_thread_in_native, id=1888873664, stack(7fff5f400000,7fff5fc00000)]
Other Threads:
1150eb000 VMThread [stack: 11c99a000,11ca9a000] [id=480878592]
11481b000 WatcherThread [stack: 11e510000,11e610000] [id=509673472]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 19136K, used 4721K [7d0000000, 7d14c0000, 7d4000000)
eden space 17024K, 20% used [7d0000000, 7d036e958, 7d10a0000)
from space 2112K, 57% used [7d10a0000, 7d11cde40, 7d12b0000)
to space 2112K, 0% used [7d12b0000, 7d12b0000, 7d14c0000)
concurrent mark-sweep generation total 131656K, used 60215K [7d4000000, 7dc092000, 7f0000000)
concurrent-mark-sweep perm gen total 250736K, used 152191K [7f0000000, 7ff4dc000, 800000000)
Code Cache [115801000, 115f62000, 118801000)
total_blobs=2690 nmethods=1785 adapters=864 free_code_cache=42860416 largest_free_block=51968
Virtual Machine Arguments:
JVM Args: -Dosgi.requiredJavaVersion=1.5 -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts -XX:MaxPermSize=256m -Xms40m -Xmx512m -Xdock:icon=../Resources/Eclipse.icns -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 4096M, Free = 275M
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 ...ple.CoreServices.CarbonCore 0x00007fff82c67a62 CallExceptionHandler(OpaqueCollection*, short) + 42
1 ...ple.CoreServices.CarbonCore 0x00007fff82c8171c GetTaggedCollectionItem + 131
2 com.apple.HIServices 0x00007fff82f87d46 GetIndexedReceiveHandler + 28
3 com.apple.HIServices 0x00007fff82f87f0f DoDropMessage + 131
4 com.apple.HIServices 0x00007fff82f88384 SendDropMessage + 31
5 com.apple.HIServices 0x00007fff82f89ce1 DragInApplication + 454
6 com.apple.HIServices 0x00007fff82f8a749 CoreDragStartDragging + 634
7 com.apple.AppKit 0x00007fff812bd938 -[NSCoreDragManager _dragUntilMouseUp:accepted:] + 763
8 com.apple.AppKit 0x00007fff812bd37e -[NSCoreDragManager dragImage:fromWindow:at:offset:event:pasteboard:source:slideBack:] + 1594
9 com.apple.AppKit 0x00007fff8157851e -[NSWindow(NSDrag) dragImage:at:offset:event:pasteboard:source:slideBack:] + 146
10 libswt-pi-cocoa-3735.jnilib 0x0000000122010687 Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSend__JJJLorg_eclipse_swt_internal_cocoa_NSPoint_2Lorg_eclipse_swt_internal_cocoa_NSSize_2JJJZ + 242
11 ??? 0x0000000115811d6e 0 + 4655750510
12 ??? 0x0000000115806929 0 + 4655704361
13 ??? 0x000000011580685a 0 + 4655704154
14 ??? 0x000000011580685a 0 + 4655704154
15 ??? 0x0000000115a64190 0 + 4658184592
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff84200c0a kevent + 10
1 libSystem.B.dylib 0x00007fff84202add _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff842027b4 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff842022de _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff84201c08 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff84201aa5 start_wqthread + 13
Thread 2: Java: Exception Handler Thread
0 libSystem.B.dylib 0x00007fff841e7d7a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff841e83ed mach_msg + 59
2 libSystem.B.dylib 0x00007fff84264a17 mach_msg_server + 468
3 libclient64.dylib 0x0000000113a0e72b jio_snprintf + 41445
4 libclient64.dylib 0x0000000113a0e5e3 jio_snprintf + 41117
5 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
6 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
7 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 3: Java: Gang worker#0 (Parallel GC Threads)
2 libclient64.dylib 0x0000000113a0d863 jio_snprintf + 37661
3 libclient64.dylib 0x0000000113a0d723 jio_snprintf + 37341
4 libclient64.dylib 0x0000000113a0d682 jio_snprintf + 37180
5 libclient64.dylib 0x0000000113a0d25d jio_snprintf + 36119
6 libclient64.dylib 0x0000000113a0d103 jio_snprintf + 35773
7 libclient64.dylib 0x0000000113a25f04 jio_vsnprintf + 312
8 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
9 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
10 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 4: Java: Gang worker#1 (Parallel GC Threads)
Thread 5: Java: Gang worker#2 (Parallel GC Threads)
Thread 6: Java: Gang worker#3 (Parallel GC Threads)
Thread 7: Java: Concurrent Mark-Sweep GC Thread
2 libclient64.dylib 0x0000000113a0d8f5 jio_snprintf + 37807
3 libclient64.dylib 0x0000000113a2c4aa jio_vsnprintf + 26334
4 libclient64.dylib 0x0000000113a0d25d jio_snprintf + 36119
5 libclient64.dylib 0x0000000113a0d103 jio_snprintf + 35773
6 libclient64.dylib 0x0000000113b02a39 JVM_Close + 211677
7 libclient64.dylib 0x0000000113b02923 JVM_Close + 211399
8 libclient64.dylib 0x0000000113a2c325 jio_vsnprintf + 25945
9 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
10 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
11 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 8: Java: VM Thread
6 libclient64.dylib 0x0000000113aa3ef7 JVM_Lseek + 188645
7 libclient64.dylib 0x0000000113aa3c47 JVM_Lseek + 187957
Thread 9: Java: Reference Handler
4 libclient64.dylib 0x0000000113ab24ff JVM_MonitorWait + 3999
5 libclient64.dylib 0x0000000113ab198c JVM_MonitorWait + 1068
6 libclient64.dylib 0x0000000113ab15fa JVM_MonitorWait + 154
7 libjvmlinkage.dylib 0x0000000100719b9b JVM_MonitorWait + 59
8 ??? 0x0000000115811d6e 0 + 4655750510
9 ??? 0x0000000115d27c80 0 + 4661083264
10 ??? 0x00000000fe01f2c6 0 + 4261540550
Thread 10: Java: Finalizer
9 ??? 0x000000011596f4bc 0 + 4657181884
Thread 11: Java: Surrogate Locker Thread (Concurrent GC)
6 libclient64.dylib 0x0000000113a0d06a jio_snprintf + 35620
7 libclient64.dylib 0x0000000113ac2111 JVM_IsPrimitiveClass + 6521
8 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
9 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
10 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
11 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
12 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 12: Java: Signal Dispatcher
0 libSystem.B.dylib 0x00007fff841e7db6 semaphore_wait_trap + 10
1 libclient64.dylib 0x0000000113ac2953 JVM_IsPrimitiveClass + 8635
2 libclient64.dylib 0x0000000113ac23da JVM_IsPrimitiveClass + 7234
3 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
4 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
Thread 13: Java: C2 CompilerThread0
7 libclient64.dylib 0x0000000113ac91cd JVM_Write + 345
8 libclient64.dylib 0x0000000113ac37c3 JVM_IsPrimitiveClass + 12331
9 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
10 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
11 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
12 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
13 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 14: Java: C2 CompilerThread1
Thread 15: Java: Low Memory Detector
7 libclient64.dylib 0x0000000113ac51c8 JVM_IsPrimitiveClass + 18992
Thread 16: Java: VM Periodic Task Thread
4 libclient64.dylib 0x0000000113ac72fa JVM_IsPrimitiveClass + 27490
Thread 17: Java: Poller SunPKCS11-Darwin
3 libclient64.dylib 0x0000000113bb0308 JVM_GetClassInterfaces + 11190
4 libclient64.dylib 0x0000000113bbee9a JVM_Sleep + 191
5 libjvmlinkage.dylib 0x000000010071a6ee JVM_Sleep + 62
6 ??? 0x0000000115811d6e 0 + 4655750510
7 ??? 0x000000011580685a 0 + 4655704154
8 ??? 0x0000000115806d34 0 + 4655705396
9 ??? 0x0000000115801438 0 + 4655682616
10 libclient64.dylib 0x0000000113aa50ba JVM_Lseek + 193192
11 libclient64.dylib 0x0000000113ab1148 JVM_StartThread + 2565
12 libclient64.dylib 0x0000000113ab103e JVM_StartThread + 2299
13 libclient64.dylib 0x0000000113ab0fde JVM_StartThread + 2203
14 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
15 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
16 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
17 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
18 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 18: Java: Framework Active Thread
4 libclient64.dylib 0x0000000113ab2509 JVM_MonitorWait + 4009
9 ??? 0x000000011580685a 0 + 4655704154
10 ??? 0x0000000115806d34 0 + 4655705396
11 ??? 0x0000000115801438 0 + 4655682616
12 libclient64.dylib 0x0000000113aa50ba JVM_Lseek + 193192
13 libclient64.dylib 0x0000000113ab1148 JVM_StartThread + 2565
14 libclient64.dylib 0x0000000113ab103e JVM_StartThread + 2299
15 libclient64.dylib 0x0000000113ab0fde JVM_StartThread + 2203
16 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
17 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
18 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
19 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
20 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 19: Java: State Data Manager
Thread 20: Java: Start Level Event Dispatcher
10 ??? 0x000000011580685a 0 + 4655704154
11 ??? 0x00000001158069b3 0 + 4655704499
12 ??? 0x0000000115801438 0 + 4655682616
13 libclient64.dylib 0x0000000113aa50ba JVM_Lseek + 193192
14 libclient64.dylib 0x0000000113ab1148 JVM_StartThread + 2565
15 libclient64.dylib 0x0000000113ab103e JVM_StartThread + 2299
16 libclient64.dylib 0x0000000113ab0fde JVM_StartThread + 2203
17 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
18 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
19 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
20 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
21 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 21: Java: Framework Event Dispatcher
Thread 22: Java: [Timer] - Main Queue Handler
Thread 23: Java: Worker-JM
10 ??? 0x0000000115801438 0 + 4655682616
11 libclient64.dylib 0x0000000113aa50ba JVM_Lseek + 193192
12 libclient64.dylib 0x0000000113ab1148 JVM_StartThread + 2565
13 libclient64.dylib 0x0000000113ab103e JVM_StartThread + 2299
14 libclient64.dylib 0x0000000113ab0fde JVM_StartThread + 2203
15 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
16 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
17 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
18 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
19 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 24: Java: Bundle File Closer
Thread 25: Java: Java indexing
11 ??? 0x0000000115806d34 0 + 4655705396
Thread 26: Java: Worker-3
Thread 27: Java: Provisioning Event Dispatcher
Thread 28: Java: MultiThreadedHttpConnectionManager cleanup
10 ??? 0x00000001158069b3 0 + 4655704499
Thread 29: Java: [ThreadPool Manager] - Idle Thread
Thread 30: Java: JavaScript indexing
Thread 31: Java: 703254587@qtp-1704392431-1 - Acceptor0 SelectChannelConne
1 libnio.jnilib 0x000000011ea5c523 Java_sun_nio_ch_KQueueArrayWrapper_kevent0 + 98
2 ??? 0x0000000115811d6e 0 + 4655750510
3 ??? 0x000000011580696e 0 + 4655704430
4 ??? 0x000000011580696e 0 + 4655704430
5 ??? 0x000000011580696e 0 + 4655704430
6 ??? 0x000000011580696e 0 + 4655704430
7 ??? 0x000000011580696e 0 + 4655704430
8 ??? 0x000000011580685a 0 + 4655704154
Thread 32: Java: Timer-0
Thread 33: Java: AWT-Shutdown
Thread 34: Java: Java2D Disposer
12 ??? 0x0000000115806d34 0 + 4655705396
13 ??? 0x0000000115801438 0 + 4655682616
14 libclient64.dylib 0x0000000113aa50ba JVM_Lseek + 193192
15 libclient64.dylib 0x0000000113ab1148 JVM_StartThread + 2565
16 libclient64.dylib 0x0000000113ab103e JVM_StartThread + 2299
17 libclient64.dylib 0x0000000113ab0fde JVM_StartThread + 2203
18 libclient64.dylib 0x0000000113ab0e80 JVM_StartThread + 1853
19 libclient64.dylib 0x0000000113ab0c95 JVM_StartThread + 1362
20 libclient64.dylib 0x0000000113a0d1c4 jio_snprintf + 35966
21 libSystem.B.dylib 0x00007fff84220fd6 _pthread_start + 331
22 libSystem.B.dylib 0x00007fff84220e89 thread_start + 13
Thread 35:
2 com.apple.CoreFoundation 0x00007fff835d0932 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x00007fff835cfdbf CFRunLoopRunSpecific + 575
4 com.apple.Foundation 0x00007fff8562023f +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 297
5 com.apple.Foundation 0x00007fff855a1204 __NSThread__main__ + 1429
Thread 36: com.apple.CFSocket.private
0 libSystem.B.dylib 0x00007fff8422b932 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x00007fff835f2498 __CFSocketManager + 824
Thread 37: Java: 908505087@qtp-1704392431-6
Thread 38: Java: derby.antiGC
Thread 39: Java: Timer-11
11 ??? 0x000000011580685a 0 + 4655704154
14 lib
[Updated on: Wed, 06 July 2011 14:54] Report message to a moderator
| Re: BIRT crashes on Mac OS X Snow Leopard [message #694447 is a reply to message #693565] |
Fri, 08 July 2011 11:43   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Any chance you could open a bug for this?
Jason
On 7/6/2011 2:53 PM, diddy wrote:
> Eclipse BIRT keeps on crashing when adding certain report elements. I
> Version: 3.7 (3.7)
> Report Version: 6
> Java information:
> macosx-amd64)
> j
> j
> j
> J
> j
> j
> j
> J
> j
> j
> j
> j
> j
> j
> j
> j
> j
> j
> j
> j
> j
> j
> j
> Other Threads:
> Heap
> 7d4000000)
> -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts Java
> Command: <unknown>
> + 242
> Thread 35:
> Thread 40: Java: derby.rawStoreDaemon
> 10 ??? 0x0000000115806a82 0 + 4655704706
> Thread 41: Java: Worker-13
> Thread 42: Java: Worker-15
Jason Weathersby
BIRT Exchange
Current Time: Tue May 21 07:24:05 EDT 2013
Powered by FUDForum. Page generated in 0.09001 seconds
