Home » Modeling » Modeling (top-level project) » how to use uuid as data type in a classs
how to use uuid as data type in a classs [message #695126] Mon, 11 July 2011 00:44 Go to next message
Jackey Cheung is currently offline Jackey Cheung
Hi, I'm new to EMF. I'm trying to describe a class in EMF, in Java code it is:
public class Pet
protected UUID id;
protected String name;
// other stuffs
I've also tried to create a EDataType, but I can't find UUID in the base type list.
When I tried to add the attribute "id" to EMF model, I can't find java.util.UUID in the list. How should I do it?
[Updated on: Mon, 11 July 2011 00:49]
Report message to a moderator
Re: how to use uuid as data type in a classs [message #695543 is a reply to message #695126] Mon, 11 July 2011 20:24 Go to previous message
Ed Merks is currently offline Ed Merks
Jackey,
Please ask EMF questions on the eclipse.tools.emf forum/newsgroup.
You'll need to create your own EDataType for this. The introductory
overview has a section about how to do that.
> code it is:
> public class Pet
> protected UUID id;
> // other stuffs
Previous Topic:Item Providers causing memory Leak?
Next Topic:Visual model of struts-config.xml
Current Time: Tue May 28 15:54:49 EDT 2013
Powered by FUDForum. Page generated in 0.01525 seconds
