Home » Eclipse Projects » DTP » Create table using SQL Scrapbook(Datatype length is doubled)
Create table using SQL Scrapbook [message #695495] Mon, 11 July 2011 17:50 Go to next message
Swati Sapar is currently offline Swati Sapar
I have connected to DB2 using the DTP framework.
I am creating tables by typing the query in SQL Scrap book.(Right Click -Execute All)
CREATE TABLE TableName(
Column1 INTEGER,
Column2 VARGRAPHIC(10),
Column3 VARGRAPHIC(25),
Column4 VARGRAPHIC(25),
Column5 VARGRAPHIC(25),
Column6 VARGRAPHIC(25),
Column7 VARGRAPHIC(100)
The table is created fine, but the datatypes lengths seems to be doubled. Why is this so ?
index.php/fa/3329/0/
  • Attachment: DataMap.png
    (Size: 64.25KB, Downloaded 842 times)
Re: Create table using SQL Scrapbook [message #733495 is a reply to message #695495] Tue, 04 October 2011 17:44 Go to previous message
Brian Payton is currently offline Brian Payton
Hi Swati,
I suspect that is because VARGRAPHIC is a "double-byte" datatype. It
uses two bytes to encode the character, rather than one. (SQL was
developed before UNICODE was created.)
> Column1 INTEGER,
Previous Topic:DTP - Unable to identify some datatypes
Next Topic:SQL scrapbook parse Oracle SQL and tell where there is an error?
Current Time: Tue May 21 08:19:56 EDT 2013
Powered by FUDForum. Page generated in 0.01717 seconds
