Home » Eclipse Projects » Eclipse Platform » IncrementalProjectBuilder delta - leave it for the next time?
IncrementalProjectBuilder delta - leave it for the next time? [message #695224] Mon, 11 July 2011 06:11
Timotei D is currently offline Timotei D
Member
Hi everyone!
I've seen that the IncremenetalProjectBuilder has the method:
protected IProject[] build( ... )
The javadoc says we can return projects not processed.
However, I have the following situation: When doing a non-full build there is a chance that some files were not processed (by my plugin) due to different constraints. I would like to leave those files in the "unprocessed" (added/removed/changed) state, for the next project build call. Is that possible?
So, for example, I have the files: project/myfile, project/otherfile.
I would process the myfile, but otherfile NOT. The next time I get a build call (say, with other changes also), I'd like to get the "otherfile" in the delta again. Is that possible?
One thing I thought, is to memorize in the builder instance the unprocessed files. However, I don't think it's a good idea, one reason being that I would need to persist them somehow.
Any ideas?
Thanks.
Previous Topic:run a process in eclipse plugin console
Next Topic:How do I install documentation for new API?
Current Time: Sat May 18 04:40:58 EDT 2013
Powered by FUDForum. Page generated in 0.07487 seconds
