Home » Modeling » OCL » oclAsType for external classes
oclAsType for external classes [message #694502] Fri, 08 July 2011 13:56 Go to next message
Daniel Strueber is currently offline Daniel Strueber
Hey,
Let's say I have an EClass A with a EReference b of the type EClass C that contains an EAttribute d.
A and C are part of different metamodels.
So when I type the following into the Interactive OCL console:
A.b.oclAsType(C).d
"Unrecognized variable: (C)" is returned.
Can't I use an external EClass's features in an OCL expression or am I missing something?
Daniel
Re: oclAsType for external classes [message #694535 is a reply to message #694502] Fri, 08 July 2011 15:13 Go to previous messageGo to next message
HI Daniel
Which version of Eclipse OCL are you using? Some versions complain about
a variable for a type.
It should work, but "A.b" seems an unlikely start. A seems to be an
EClass rather than an instance.
Are you sure that the meta-model is in scope? I would expect to see a
MM2::C qualification to specify the package.
Ed Willink
On 08/07/2011 18:56, forums-noreply@eclipse.org wrote:
> Hey,
> A.b.oclAsType(C).d
> missing something?
> Daniel
Re: oclAsType for external classes [message #694592 is a reply to message #694535] Fri, 08 July 2011 18:52 Go to previous message
You're right about A.b not being a proper start, of course I was using an instance rather than the class.
The package qualification was exactly what I couldn't figure out on my own - that did it, thanks for your help!
[Updated on: Fri, 08 July 2011 18:54]
Report message to a moderator
Previous Topic:Navigating a non-navigable (one way) association
Next Topic:How do I determine if a class has no one inhereting from it?
Current Time: Sun May 26 03:44:39 EDT 2013
Powered by FUDForum. Page generated in 0.01535 seconds
