| HTTP Status 404 [message #693191] |
Tue, 05 July 2011 21:40  |
duanqi Messages: 11 Registered: June 2011 |
Junior Member |
I have done two demos which depend on struts2 framework in Virgo.After deployed the demo in Virgo,the STS reported the core message:
<WE0001I> Starting web bundle 'struts2_sample' version '1.0.0' with context path '/struts2_sample'.
So,I tried to input "localhost:8080/struts2_sample" in browser which repsoned with the request resource(/struts_sample/) is not available
did that mean Virgo didn't load the web.xml file or the other reasons?
| Re: HTTP Status 404 [message #693451 is a reply to message #693327] |
Wed, 06 July 2011 09:57   |
Junior Member |
Hi Glyn,
It's my careless to type the incorrect content while the browser just output the request resource(/struts2_sample/) is not available.
I had checked log file which didn't report any errors,neither the console of STS.So I suspected that the Virgo didn't load the web.xml of struts2_sample.could you give me some other suggestions,Very thanks.
duanqi
[Updated on: Fri, 08 July 2011 08:57] Report message to a moderator
| Re: HTTP Status 404 [message #693986 is a reply to message #693497] |
Thu, 07 July 2011 11:24   |
Junior Member |
Hi Glyn,
I really hope you can read my statement over and give me some advices.your help will affect my work a lot.Very thanks advanced.My statement is:
My goal:I want integrate SSH(Struts2,Spring,Hibernate) with Virgo.Because I had own some bundles which consist of SSH framework and my applications based on the SSH.In order to take advantage of Virgo server and know more about OSGi,so I decide to run my applications in Virgo.
My process:Firstly,I integrate the Struts2 in Virgo.I have made Struts2.core bundle into repository/usr file.Then I try to write some demos based on Struts2.core in Virgo.When STS compile the demo successfully,I try to visit this demo by browser which response with the content of HTTP Status 404.
My questions: 1、how can I know the Virgo load Web applications clearly or the Virgo communicate with SSH?
2、need I analysis the code of Virgo?
3、Where can I download the code of Virgo?
4、could you help me to organize my thoughts where should I start from?
very very thanks!
[Updated on: Fri, 08 July 2011 08:46] Report message to a moderator
FUDForum. Page generated in 0.05703 seconds
