| Circular references with identity id - what's the right way? [message #693883] |
Thu, 07 July 2011 08:44 |
Brendan Healey Messages: 12 Registered: May 2010 |
Junior Member |
I've had a good look around but can't see anything definitive about how to do this
so any help would be appreciated (no doubt I've missed something but I tried).
I've got two entities with a circular reference, each using identity id columns.
In this case I'm working with detached entities from JSF managed beans using
container managed persistence (@PersistenceContext). I've got some simple EJB
methods which just call EntityManager merge() and persist() methods.
My problem is that sometimes, and only sometimes, do I get an integrity constraint
violation exception on the line below marked ***. I see the sequence of events
like this:
1. EntityManager.persist() is called on a new Plog() within a transaction which
commits, NO flush or refresh.
2. Instantiate new Tlog(), setup link from this to the Plog from step 1 and
persist this within a transaction which commits. Again no flush or refresh.
3. Do some work which modifies the Tlog instance from step 2, merge these
changes into the persistent context taking care to return the latest version
after the merge (else OptimisticLockException).
4. At this point the Tlog has a reference to the Plog. Now setup a reference
from the Plog to the Tlog we just persisted. When I try to merge this change
(ejb.merge(plog)) sometimes, and only sometimes, I get an integrity constraint
violation (error code 1452) for the foreign key in the plog table which
references the id of the tlog table.
If this description is confusing I apologise, please just have a look at the code
below.
So question 1) why is it working sometimes and not others? I was testing away
happily yesterday, turn off the computer, get up in the morning and I'm getting
the exception?
2) why does it seem to work reliably one way but not the other, i.e. I never
have a problem setting up the link from the tlog to the plog, only the other
way round, despite using the exact same mechanism.
3) I gather that identity columns may not be the best generation method to use
in this scenario, would a table or sequence strategy be a magic bullet?
4) I'm not explicitly using flush(), refresh() or both, should I be? if so,
why doesn't it always not work?
I read somewhere that with a circular reference the persistence provider does
a shallow insert, so I'm using nullable = true on the @JoinColumn, but this
is the default so I don't suppose this is going to make any difference.
After I call my ejb.persist() method I can always output the id of the newly
persisted entity in debug output, so it's then confusing to get the constraint
violation.
@Entity
@Table(name = "plog")
public class Plog implements Serializable {
private static final long serialVersionUID = 1L;
@Id
@GeneratedValue(strategy=GenerationType.IDENTITY)
@Column(name = "id")
private long id;
@Version
@Column(name = "version")
private Integer version;
@OneToOne
@JoinColumn(name = "tlog", referencedColumnName = "id", nullable = true)
private Tlog tlog;
//getters & setters removed
@Entity
@Table(name = "tlog")
public class Tlog implements Serializable {
@Id
@GeneratedValue(strategy = GenerationType.IDENTITY)
private long id;
@Version
@OneToOne
@JoinColumn(name = "plog", referencedColumnName = "id", nullable = true)
private Plog plog;
@EJB private MyEjb ejb;
Plog plog = new Plog();
ejb.persist(plog); // just calls EntityManager.persist()
Tlog tlog = new Tlog();
tlog.setPlog(plog);
ejb.persist(tlog);
// do some work, changes tlog
tlog = ejb.merge(tlog); // returns newly merged entity
plog.setTlog(tlog);
ejb.merge(plog); // *** integrity constraint violation here - sometimes!
EclipseLink 2.3
Glassfish 3.1
MySQL 5.5.12 with InnoDB
Thanks for any help,
Brendan.
[Updated on: Thu, 07 July 2011 11:44] Report message to a moderator
FUDForum. Page generated in 0.09795 seconds
