| (no subject) [message #693255] |
Wed, 06 July 2011 02:13  |
Michael Gerzabek Messages: 16 Registered: June 2011 |
Junior Member |
I try to setup the wiki.eclipse.org/EclipseLink/Examples/MOXy/GettingStarted as an OSGI bundle.
MANIFEST.MF:
Require-Bundle: javax.xml.bind;bundle-version="2.2.0",
org.eclipse.persistence.moxy;bundle-version="2.1.3"
Launch configuration:
org.eclipse.persistence.core startlevel 2 auto-start true
my bundle startlevel 3 auto-start true
When running equinox I get the exception:
javax.xml.bind.JAXBException
- with linked exception:
[java.lang.ClassNotFoundException: org.eclipse.persistence.jaxb.JAXBContextFactory]
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:186)
at javax.xml.bind.ContextFinder.find(ContextFinder.java:330)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:618)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:565)
What do I miss here? How do I have to setup my bundle project when using MOXy in an OSGI bundle?
Michael
| Re: (no subject) [message #693936 is a reply to message #693927] |
Thu, 07 July 2011 10:04  |
Junior Member |
This is interesting!
I tried three different calls, only the first of them works:
JAXBContext jaxbContext = JAXBContext.newInstance(
"org.jessas.annotator.jaxb.moxy",
Customer.class.getClassLoader());
These two
Customer.class, Address.class, PhoneNumber.class);
JAXBContext jaxbContext = JAXBContext.newInstance(new Class[] {
Customer.class, Address.class, PhoneNumber.class },
Collections.<String, Object> emptyMap());
both result in
at org.jessas.annotator.jaxb.Activator.doit(Activator.java:77)
at org.jessas.annotator.jaxb.Activator.start(Activator.java:33)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
Caused by: java.lang.ClassNotFoundException: org.eclipse.persistence.jaxb.JAXBContextFactory
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.eclipse.core.runtime.internal.adaptor.ContextFinder.loadClass(ContextFinder.java:129)
at javax.xml.bind.ContextFinder.safeLoadClass(ContextFinder.java:480)
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:184)
... 18 more
Anyway. I see how easy it is to use moxy and am happy to provide the ClassLoader by hand. This way I can use it in my bundle an proceed with my requirements.
Thank you for your kind support.
Michael
| (no subject) [message #693939 is a reply to message #693739] |
Thu, 07 July 2011 09:48  |
Shaun Smith Messages: 189 Registered: July 2009 |
When you pass an array of classes the classloader used by the JAXB bootstrap classes is obtained from the classes themselves. So this means that the domain classes' bundle would need to have visibility to MOXy. Again, JAXB wasn't designed for OSGi so the API isn't ideal.
--Shaun
FUDForum. Page generated in 0.01889 seconds
