Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » TPTP framework question
TPTP framework question [message #67241] Fri, 21 April 2006 04:16 Go to next message
strus is currently offline strus
I am not sure this newsgroup is the good one for my question, but I haven't find
another place to put this question.
We developed an RCP Application based on Eclipse 3.1.2 which (and to sum up)
displays the processes running on the machine with several information using a
JNI and a native library, and where we can run our performance tools to analyze
what happens. We are also able to profile the running processes.
The current version only work on a localhost which is not a good idea when we
want to analyze the performances of a system.
I would like to know if TPTP can be easily extended to allow:
1) Defining our library as an agent for TPTP to retrieve our data from a target
host and display the result in our own perspective ?
2) Is it possible to use the 'Host' preferences to retrieve information on a
machine to be able to remotely run system commands on this machine, and transfer
result file from the target machine to the localhost ?
3) Is the 'Host' clearly identify (OS, OS-VERSION, ...) or TPTP doesn't need
these informations ?
4) Is it possible to extends the existing TPTP menus to add our own actions ?
5) Is it possible to put the TPTP framework or just some part of it into an
stand-alone RCP application design only for performances analysis ?
To summarize, currently TPTP seems very good to analyze Java relative stuff, we
would like to add the possibility to analyze processes deeply whatever the
language used with our own tools and plugins.
Thanks.
Re: TPTP framework question [message #67557 is a reply to message #67241] Fri, 21 April 2006 15:47 Go to previous messageGo to next message
Andy Kaylor is currently offline Andy Kaylor
> target host and display the result in our own perspective ?
Yes, you should be able to use TPTP to do this very easily.
I would suggest that you use the new Agent Controller as it has a nice
framework for agent development that should be able to get you up and
running quickly. We have some example client and agent code that does basic
data transfer to help you get started.
> a machine to be able to remotely run system commands on this machine, and
> transfer result file from the target machine to the localhost ?
I'm not sure I understand all the implications of this quesion. Using TPTP,
you can start a remote process and get console output redirected to a local
object for processing. You can also transfer remote files to the local
system if you know their location.
> need these informations ?
Currently TPTP does not provide this information. We have an open feature
request to develop an agent to return information about the remote system,
but there are no concrete plans for when that will be developed.
> actions ?
Yes. A lot of the TPTP code is below the UI level, and the framework code
is designed to be independent of the user interface. But if there are parts
of the TPTP user interface that you would like to include in your RCP
application, you will be able to customize them.
> an stand-alone RCP application design only for performances analysis ?
Yes. The TPTP runtime is broken down into several plugins. You should be
able to choose the plugins you need and include them in your RCP app.
-Andy
Re: TPTP framework question [message #67808 is a reply to message #67557] Mon, 24 April 2006 09:15 Go to previous messageGo to next message
This is exactly what I want.
So, which kind of connection is established between the remote client and
eclipse TPTP ?
>>actions ?
> -Andy
Thank you
Matthieu
Re: TPTP framework question [message #67890 is a reply to message #67808] Mon, 24 April 2006 14:05 Go to previous messageGo to next message
Randy D. Smith is currently offline Randy D. Smith
strus_fr wrote:
>>> doesn't need these informations ?
>> feature request to develop an agent to return information about the
>> remote system, but there are no concrete plans for when that will be
>> developed.
> and eclipse TPTP ?
I'm getting confused here... reminds me of the early days of X11 when
"client" and "server" often seemed turned on their heads. The problem is
that I think most TPTP terminology turns on the client being the local
side of things (it's often the Eclipse workbench, but doesn't have to
be) and the "agent" being the remote thing that receives commands from
the client and returns data to the client (with either side of things,
sending commands or receiving data, being optional behavior).
So let me see if I can be clear on terminology while drawing you a
verbal picture, and then you can tell me how to translate betweeen our
terminologies.
On some local machine, as I said, you have a client. This wants to have
work done and receive data as a result. This side communicates to the
agent controller (AC, running on a remote system potentially, though it
also can run locally) through a normal socket (to port 10006 by default
for the "new technology AC"), which acts on its behalf. The AC can
launch processes (console processes, agents, etc.), and provides the
communication channel between the two (client and agent). The
communication channel is actually (potentially) many channels... a
command channel for issuing commands, and one or more data channels for
data communication between the two. E.g., for a "normal" (console)
process, you need three data channels... for stdin, stdout, and stderr.
The connection between AC and Agent is "wrapped up" in the API... you
really don't have to (and probably don't want to) know the details of
Socket/NamedPipe/SharedMemory usage...
(Note that whether these command and data channels are each physically
separate or physically the same but logically separate is just an
implementation issue, and potentially a configurable one.)
It sounds like you're looking at things more from the agents
perspective... if so, then try looking at it from this perspective... if
you have some kind of process that receives commands (in some form) and
generates data, you'll want to modify that process to become an agent in
the following way:
(1) when the process starts up, registerAgent with the AC to let it know
you exist, can accept connections, and do your work on some clients behalf,
(2) implement a processCommand that "receives commands" indirectly from
the client through the AC instead of directly from the client, ... more
or less just a "packaging" of your command handling, and
(3) implement sendData that provides the resulting information back to
the client.
I'm assuming in all this you're willing to use the new technology AC
framework, that your agent will extend an agent framework (like
BaseCollector), and thus you get a lot of the necessary scaffolding that
lets it be as simple as the 1..2..3.. above. Your agent will inherit a
multithreaded approach with at least the processCommands getting invoked
from one thread, and hopefully you driving the sendData from another,
with perhaps a third thread sitting in waitForTermination.
That's sort of the verbal picture... you can get a little bit of
concreteness around this by downloading the "new technology Agent
Controller SDK" and looking at the Samples included in it...
specifically ConsoleTestClient, SimpleAppl, SampleClient, and
TimeCollector. They might clear up any confusion the above creates in
your mind.
I also might recommend you look at the PerfmonAgent in the Samples... it
used to be an agent with the old AC (called the "RAC"... actually, it
still is an agent in its original form with the RAC distribution), and
it was modified to behave in just the 1..2..3.. form I describe above.
HTH,
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: TPTP framework question [message #67973 is a reply to message #67890] Tue, 25 April 2006 09:04 Go to previous messageGo to next message
Well, I was asking this question because we have a prototype of our plugin which
runs using a RMI-JNI communication between the remote host (the machine where
our native library runs and retrieve the data ) and the localhost (the machine
where Eclipse run). I was wondering if I could easily transform this RMI
communication with the technology used by the "new technology AC". This is the
first part of the work of our plugin.
The second part would consits in running system commands on the "remote host"
and transfer the result files on the "eclipse localhost" using the "new
technology AC".
Now, I am sure that the second part of the work can be achieved by using an
agent, but I am still not sure for the 1st part.
Thanks you. Hope this is clearer now.
Matthieu
Re: TPTP framework question [message #69209 is a reply to message #67973] Mon, 01 May 2006 13:26 Go to previous message
Hi Matthieu,
The way that the new Agent Controller is designed is that once you have a
client and an agent connected (whether locally or remotely), they can
communicate by sending each other messages through the Agent Controller.
These commands get packaged as XML fragments, though a lot of the work for
packaging and parsing these into more useful data types is handled by the
TPTP framework code.
It is basically intended to be very much like an RMI, so it should fit
nicely into what you've described.
-Andy
"strus_fr" <strus_fr@yahoo.fr> wrote in message
news:e2l6p7$83r$1@utils.eclipse.org...
> which runs using a RMI-JNI communication between the remote host (the
> machine where our native library runs and retrieve the data ) and the
> localhost (the machine where Eclipse run). I was wondering if I could
> easily transform this RMI communication with the technology used by the
> "new technology AC". This is the first part of the work of our plugin.
> host" and transfer the result files on the "eclipse localhost" using the
> an agent, but I am still not sure for the 1st part.
> Matthieu
Previous Topic:RAServer Runtime exception
Next Topic:Code Coverage
Current Time: Tue May 21 09:36:53 EDT 2013
Powered by FUDForum. Page generated in 0.01796 seconds
