Home » Eclipse Projects » Platform - User Assistance (UA) » Recommended Work Flow for Cheat Sheet Development
Recommended Work Flow for Cheat Sheet Development [message #474067] Mon, 16 June 2008 06:38 Go to next message
Eclipse User
Originally posted by: ka.xxxxx.com
I'm a bit confused about creating Cheat Sheets after reading and trying
code in this excellent article by Mike Pawlowski "Recommended Work Flow
for Cheat Sheet Development".
I'used to creating Cheat Sheets using plug-ins project with XML files etc
Trying the user assistant wizard as mentionned above, i've concluded that
Cheat Sheets still a plug-ins matter and the user assistant adds only an
elegant way to edit simple and composite Cheat Sheets.
Am I right ?
Thanks very much
Re: Recommended Work Flow for Cheat Sheet Development [message #474070 is a reply to message #474067] Mon, 16 June 2008 15:52 Go to previous messageGo to next message
Mike Pawlowski is currently offline Mike Pawlowski
I'm glad you like the article. ;)
Yes you are correct, plug-ins still matter because they are used to deploy
the cheatsheets within the workbench for users to access. The "Register
cheat sheet wizard" takes care of adding the required plug-in manifest
mark-up to make this happen.
Now if you want to edit cheatsheets and deploy them elsewhere on your own,
you are free to create and edit them using the cheatsheet wizards and
editors in a non-plug-in related project. If you change your mind, the
"Register cheat sheet wizard" will still work because it will attempt to
automatically convert the project housing the edited cheat sheet into a
plug-in project (e.g. by adding the "plugin.xml" and "MANIFEST.MF" files).
More information on the wizard can be found in the Eclipse Help InfoCenter
(or by pressing F1 within the wizard):
Plug-in development environment(PDE) user guide > Tools > Editors > Simple
Cheat Sheet Editor > Register Cheat Sheet Wizard
Mike
Re: Recommended Work Flow for Cheat Sheet Development [message #474072 is a reply to message #474070] Tue, 17 June 2008 04:14 Go to previous messageGo to next message
Eclipse User
Originally posted by: ka.xxxxxxxxxxxx.com
Thanks Mike,
Very clear and fast answer
Thank you very much
KA
Re: Recommended Work Flow for Cheat Sheet Development [message #615275 is a reply to message #474067] Mon, 16 June 2008 15:52 Go to previous messageGo to next message
Mike
Re: Recommended Work Flow for Cheat Sheet Development [message #615284 is a reply to message #474070] Tue, 17 June 2008 04:14 Go to previous messageGo to next message
Eclipse User
Thanks Mike,
Thank you very much
KA
Re: Recommended Work Flow for Cheat Sheet Development [message #691598 is a reply to message #474072] Fri, 01 July 2011 16:09 Go to previous message
Rich Payton is currently offline Rich Payton
I found this thread because I am having trouble registering the Cheat Sheets I have created. For some reason the "Register this cheat sheet" link does not appear on the Cheat Sheet Editor. I am using Eclipse 5.1 and maybe it wasn't available yet. I really don't know. Another reason might be that I have mashed two 'versions' of Eclipse together. They are not really two different versions. One 'version' is the RCP that the developers in my company create from a barebones setup of Eclipse. The other 'version' is the Eclipse SDK that I downloaded. The RCP developers took out the Cheat Sheet Editor capability that I needed, so to get it back I mashed them together by filling in all of the holes with the SDK download that were created by the RCP developers.
I either need to fix Eclipse to get the registration link back or I just need to learn how to register the Cheat Sheets manually. I'd like to learn both.
I have an inkling of what I have to do, but I don't know the details. The devil is in the details.
[Updated on: Tue, 05 July 2011 11:01]
Report message to a moderator
Previous Topic:Indigo unable to connect to marketplace
Next Topic:Problem with Keyword Index (since 3.7)
Current Time: Thu May 23 08:03:24 EDT 2013
Powered by FUDForum. Page generated in 0.02352 seconds
