Home » Archived » M2M (model-to-model transformation) » QVTO iteration() operation, acc returns nothing
QVTO iteration() operation, acc returns nothing [message #690952] Thu, 30 June 2011 09:09 Go to next message
Tom2000  is currently offline Tom2000
in the specification 2.0 i red that acc is the accumulation object and returns the things you want, so i tried one example but nothing happened. The aim is to iterate over two lists and save duplicat values in a third list.
var str : List(String) := List{"A","B","C"};
var st : List(String) := List{"A","B","D"};
var temp : Sequence(String) := Sequence{};
		str -> forEach(i){
		   temp = st -> iterate(it : String;
				acc : Sequence(String) = Sequence{"Z"} |
				if(i.equalsIgnoreCase(it))then {
					acc += it; //acc gives nothing back
					acc  -> including(it); // its empty
					//temp += it; //only direkt access works
				}endif	);
Additional Question: could i use QVT List type in javaBlackboxLibrary directly or only OCL Types?
Thank you.
Re: QVTO iteration() operation, acc returns nothing [message #690962 is a reply to message #690952] Thu, 30 June 2011 09:21 Go to previous message
Your example is a very uncomfortable mix of OCL and QVT. I would be
surprised if it is valid. I recommend pure OCL for OCL constructs e.g.
.... iterate(it : String; acc : Sequence(String) = Sequence{"Z"} | if
i.equalsIgnoreCase(it)) then acc->including(it) else acc endif) ...
Ed Willink
> str -> forEach(i){
> }endif );
> Thank you.
Previous Topic:[QVTO] Black-box problem with XML
Next Topic:After i Inject the XML using the AM3, the created model or XMI does not conform the XMI model
Current Time: Sat May 25 19:24:49 EDT 2013
Powered by FUDForum. Page generated in 0.01986 seconds
