Home » Eclipse Projects » Virgo » Problem to shutdown Virgo with altered admin password(Shutdown of Virgo Web Server does not work if the admin password was changed)
Problem to shutdown Virgo with altered admin password [message #690791] Thu, 30 June 2011 04:27 Go to next message
Martin W. is currently offline Martin W.
Hello everybody,
On a standard installation of Virgo it's possible to start and stop the server with the start and shutdown scripts. If I change the password for admin in org.eclipse.virgo.kernel.users.properties then shutdown does not work and throws an exception... Is that normal behavior? Or maybe a bug? How can I shut down Virgo if I don't want to have the standard password ("springsource")?
Thanks in advance for your help!
Best Regards,
Martin
C:\Virgo\bin>shutdown.bat
java.lang.SecurityException: Authentication failed! Credentials did not match
        at com.sun.jmx.remote.security.JMXPluggableAuthenticator.authenticationFailure(JMXPluggableAuthenticator.java:208)
        at com.sun.jmx.remote.security.JMXPluggableAuthenticator.authenticate(JMXPluggableAuthenticator.java:185)
        at sun.management.jmxremote.ConnectorBootstrap$AccessFileCheckerAuthenticator.authenticate(ConnectorBootstrap.java:201)
        at javax.management.remote.rmi.RMIServerImpl.doNewClient(RMIServerImpl.java:213)
        at javax.management.remote.rmi.RMIServerImpl.newClient(RMIServerImpl.java:180)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:305)
        at sun.rmi.transport.Transport$1.run(Transport.java:159)
        at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
        at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
        at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
        at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
        at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
        at java.lang.Thread.run(Thread.java:662)
        at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCall.java:255)
        at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:233)
        at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:142)
        at javax.management.remote.rmi.RMIServerImpl_Stub.newClient(Unknown Source)
        at javax.management.remote.rmi.RMIConnector.getConnection(RMIConnector.java:2327)
        at javax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:279)
        at javax.management.remote.JMXConnectorFactory.connect(JMXConnectorFactory.java:248)
        at org.eclipse.virgo.kernel.shutdown.ShutdownClient.doShutdown(ShutdownClient.java:63)
        at org.eclipse.virgo.kernel.shutdown.ShutdownClient.performShutdown(ShutdownClient.java:50)
        at org.eclipse.virgo.kernel.shutdown.ShutdownClient.main(ShutdownClient.java:43)
Caused by: javax.security.auth.login.FailedLoginException: Credentials did not match
        at org.eclipse.virgo.kernel.authentication.KernelLoginModule.login(KernelLoginModule.java:87)
        at javax.security.auth.login.LoginContext.invoke(LoginContext.java:769)
        at javax.security.auth.login.LoginContext.access$000(LoginContext.java:186)
        at javax.security.auth.login.LoginContext$4.run(LoginContext.java:683)
        at javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:680)
        at javax.security.auth.login.LoginContext.login(LoginContext.java:579)
        at com.sun.jmx.remote.security.JMXPluggableAuthenticator.authenticate(JMXPluggableAuthenticator.java:173)
P.S: I tried it on a Windows and on a Linux system....
Re: Problem to shutdown Virgo with altered admin password [message #690825 is a reply to message #690791] Thu, 30 June 2011 05:25 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
Do you use 2.1 or 3.0? There was a bug with the shutdown that was fixed in 3.0.0.M01
Re: Problem to shutdown Virgo with altered admin password [message #691058 is a reply to message #690825] Thu, 30 June 2011 12:02 Go to previous message
Yes, that was it...
I used 2.1, now I updated and it works.
Thank you!
[Updated on: Thu, 30 June 2011 12:02]
Report message to a moderator
Previous Topic:WebApplicationStartFailedException
Next Topic:Virgo Admin Console Bundle List Retrieval
Current Time: Tue May 21 05:33:05 EDT 2013
Powered by FUDForum. Page generated in 0.02307 seconds
