Home » Eclipse Projects » DTP » CSV import with auto-generated primary key
CSV import with auto-generated primary key [message #677448] Wed, 08 June 2011 10:48 Go to next message
Yo is currently offline Yo
I load a CSV file into a table but DTP insists on each row in the file
having a primary key. But I want DTP to genewrate that.
The rows in the CSV file do not have a primary key. In the destination
table, the first column is defined as a non-null, auto-generated primary
key. I was hoping that when the first column in the CSV is empty, that
DTP will auto-generate that column. Instead, it gives and error stating
that a null value is being assigned to a non-null column.
Is there way to get DTP to auto-generate IDs during CSV import?
I am using DTP 1.9.
Thanks, yo
Re: CSV import with auto-generated primary key [message #690467 is a reply to message #677448] Wed, 29 June 2011 10:51 Go to previous message
Brian Fitzpatrick is currently offline Brian Fitzpatrick
Yo, I don't believe there is a way to do this currently. Can you create an enhancement request?
Previous Topic:Connection error to SQL via BIRT viewer
Next Topic:New connection profile to Sybase ASE database..(problems)
Current Time: Tue Jun 18 03:18:18 EDT 2013
Powered by FUDForum. Page generated in 0.02184 seconds
