Home » Eclipse Projects » scout » AbstractTable: Dynamic Columns
AbstractTable: Dynamic Columns [message #690270] Wed, 29 June 2011 05:53 Go to next message
Adrian Moser
Member
Is there a way to add dynamic columns to an instance of AbstractTable?
I know there are several methods to add rows.
Re: AbstractTable: Dynamic Columns [message #690304 is a reply to message #690270] Wed, 29 June 2011 06:38 Go to previous messageGo to next message
Ivan Motsch is currently offline Ivan Motsch
Member
Yes, you can either directly override
AbstractTable.injectColumnsInternal(List<IColumn<?>> columnList)
or setting a ITableCustomizer to the table that delegates the add of custom columns.
ITable.setTableCustomizer(myTableCustomizer);
Using the interface ITableCustomizer also adds menus to the table header, so the user can "Add column", "Modify column", etc.
That way you have control on both, adding dynamic columns and runtime management of those.
Re: AbstractTable: Dynamic Columns [message #696724 is a reply to message #690304] Thu, 14 July 2011 13:52 Go to previous message
Adrian Moser
Member
Thank you, Ivan.
Is there a way to get rid of the additional menus (add column...) using ITableCustomizer, since I just want to add some dynamic columns, but I don't want any menu actions for the user.
[Updated on: Thu, 14 July 2011 13:54]
Report message to a moderator
Previous Topic:NullPointerException when connecting to http://localhost/TutorialMiniCrm/process
Next Topic:Summary row in table
Current Time: Sat May 18 06:04:39 EDT 2013
Powered by FUDForum. Page generated in 0.01711 seconds
