Home » Modeling » GMF (Graphical Modeling Framework) » Implementing views(Implementing diffrent views for the same model)
icon5.gif  Implementing views [message #689278] Mon, 27 June 2011 06:18 Go to next message
Mauro P. is currently offline Mauro P.
Hi all!
I'm writng becouse i need a suggest....
I'm working to a tool based on gmf.
Like in the topic's title I have to implemnt diffrent views.
Each view should hide/unide specific elemnts of the model and should be able to add new elemnts and connection, also remembering the node size and position between views.
This should presist on save and load of the diagram file.
I'm pretty new to gmf and I'm a lot confused about implement this...
I didn't find much about on the web...
If someone could give me a hint,link or book's tilte it will be really appreciated.
Tanks in advance.
Mauro
Re: Implementing views [message #689668 is a reply to message #689278] Tue, 28 June 2011 02:37 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph Gerbig
is this what you are looking for? http://wiki.eclipse.org/Graphical_Modeling_Framework/Tips#Making_figures_sensitive_to_attributes_of_semantic_elements
Ralph
Re: Implementing views [message #689672 is a reply to message #689668] Tue, 28 June 2011 02:50 Go to previous message
That's seem, but i need to experiment!!
Really tanaks!!! that should be a big hint! Thumbs Up
Previous Topic:Drag and drop from palette issue
Next Topic:Problem with setting routing example from wiki
Current Time: Fri May 24 21:04:20 EDT 2013
Powered by FUDForum. Page generated in 0.01549 seconds
