Home » Eclipse Projects » Eclipse Platform » Problem when starting Eclipse(Many handler conflicts)
Problem when starting Eclipse [message #689240] |
Mon, 27 June 2011 04:16  |
Alexey Romanov Messages: 263 Registered: May 2010 |
When starting Eclipse, many of commands are disabled. .log in metadata folder says:
!SESSION 2011-06-27 12:10:17.877 -----------------------------------------------
eclipse.buildId=M20110210-1200
java.version=1.6.0_24
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: --launcher.XXPermSize 256m -product org.eclipse.epp.package.rcp.product
Command-line arguments: -os linux -ws gtk -arch x86 --launcher.XXPermSize 256m -product org.eclipse.epp.package.rcp.product
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.459
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.459
!MESSAGE Conflict for 'org.eclipse.ui.newWizard':
HandlerActivation(commandId=org.eclipse.ui.newWizard,
handler=org.eclipse.ui.internal.handlers.WizardHandler$New,
expression=,sourcePriority=0)
handler=org.eclipse.ui.internal.handlers.WizardHandler$New@556949,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.460
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.460
!MESSAGE Conflict for 'org.eclipse.ui.file.import':
HandlerActivation(commandId=org.eclipse.ui.file.import,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Import,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Import@1249e1a,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.461
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.461
!MESSAGE Conflict for 'org.eclipse.ui.file.export':
HandlerActivation(commandId=org.eclipse.ui.file.export,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Export@b1fea4,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Export,
!MESSAGE Conflict for 'org.eclipse.ui.file.properties':
HandlerActivation(commandId=org.eclipse.ui.file.properties,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler@ee558f,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.462
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.462
!MESSAGE Conflict for 'org.eclipse.ui.file.exit':
HandlerActivation(commandId=org.eclipse.ui.file.exit,
handler=org.eclipse.ui.internal.handlers.QuitHandler@17c50b9,
handler=org.eclipse.ui.internal.handlers.QuitHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.463
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.463
!MESSAGE Conflict for 'org.eclipse.ui.window.switchToEditor':
HandlerActivation(commandId=org.eclipse.ui.window.switchToEditor,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler@120cb3,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.464
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.464
!MESSAGE Conflict for 'org.eclipse.ui.window.minimizePart':
HandlerActivation(commandId=org.eclipse.ui.window.minimizePart,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler@6bbe7,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.465
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.465
!MESSAGE Conflict for 'org.eclipse.ui.file.closePart':
HandlerActivation(commandId=org.eclipse.ui.file.closePart,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler@1d6d61d,
!MESSAGE Conflict for 'org.eclipse.ui.window.preferences':
HandlerActivation(commandId=org.eclipse.ui.window.preferences,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler@1e33bb8,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.466
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.466
!MESSAGE Conflict for 'org.eclipse.ui.views.showView':
HandlerActivation(commandId=org.eclipse.ui.views.showView,
handler=org.eclipse.ui.handlers.ShowViewHandler,
handler=org.eclipse.ui.handlers.ShowViewHandler@113f501,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.467
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.467
!MESSAGE Conflict for 'org.eclipse.ui.help.displayHelp':
HandlerActivation(commandId=org.eclipse.ui.help.displayHelp,
handler=org.eclipse.ui.internal.handlers.DisplayHelpHandler@1fecaeb,
handler=org.eclipse.ui.internal.handlers.DisplayHelpHandler,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.468
!MESSAGE Conflict for 'org.eclipse.ui.perspectives.showPerspective':
HandlerActivation(commandId=org.eclipse.ui.perspectives.showPerspective,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler@190dc79,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.468
!MESSAGE Conflict for 'org.eclipse.ui.navigate.showIn':
HandlerActivation(commandId=org.eclipse.ui.navigate.showIn,
handler=org.eclipse.ui.internal.ShowInHandler@1def3f5,
handler=org.eclipse.ui.internal.ShowInHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.562
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.562
!MESSAGE Conflict for 'org.eclipse.ui.window.activateEditor':
HandlerActivation(commandId=org.eclipse.ui.window.activateEditor,
handler=org.eclipse.ui.internal.ActivateEditorHandler,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.563
!MESSAGE Conflict for 'org.eclipse.ui.window.showSystemMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showSystemMenu,
handler=org.eclipse.ui.internal.ShowPartPaneMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.566
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.566
!MESSAGE Conflict for 'org.eclipse.ui.window.showViewMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showViewMenu,
handler=org.eclipse.ui.internal.ShowViewMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.567
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.567
!MESSAGE Conflict for 'org.eclipse.ui.file.close':
HandlerActivation(commandId=org.eclipse.ui.file.close,
handler=org.eclipse.ui.internal.CloseEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.568
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.568
!MESSAGE Conflict for 'org.eclipse.ui.file.closeAll':
HandlerActivation(commandId=org.eclipse.ui.file.closeAll,
handler=org.eclipse.ui.internal.CloseAllHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.569
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.569
!MESSAGE Conflict for 'org.eclipse.ui.file.closeOthers':
HandlerActivation(commandId=org.eclipse.ui.file.closeOthers,
handler=org.eclipse.ui.internal.CloseOthersHandler,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.570
!MESSAGE Conflict for 'org.eclipse.ui.ToggleCoolbarAction':
HandlerActivation(commandId=org.eclipse.ui.ToggleCoolbarAction,
handler=org.eclipse.ui.internal.handlers.ToggleCoolbarHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.571
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.571
!MESSAGE Conflict for 'org.eclipse.ui.window.nextEditor':
HandlerActivation(commandId=org.eclipse.ui.window.nextEditor,
handler=org.eclipse.ui.internal.CycleEditorHandler:true,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.572
!MESSAGE Conflict for 'org.eclipse.ui.window.previousEditor':
HandlerActivation(commandId=org.eclipse.ui.window.previousEditor,
handler=org.eclipse.ui.internal.CycleEditorHandler:false,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.573
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.573
!MESSAGE Conflict for 'org.eclipse.ui.window.nextView':
HandlerActivation(commandId=org.eclipse.ui.window.nextView,
handler=org.eclipse.ui.internal.CycleViewHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.574
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.574
!MESSAGE Conflict for 'org.eclipse.ui.window.previousView':
HandlerActivation(commandId=org.eclipse.ui.window.previousView,
handler=org.eclipse.ui.internal.CycleViewHandler:false,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.575
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.575
!MESSAGE Conflict for 'org.eclipse.ui.window.nextPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.nextPerspective,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.576
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.576
!MESSAGE Conflict for 'org.eclipse.ui.window.previousPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.previousPerspective,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:false,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.577
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.577
!MESSAGE Conflict for 'org.eclipse.ui.window.closeAllPerspectives':
HandlerActivation(commandId=org.eclipse.ui.window.closeAllPerspectives,
handler=org.eclipse.ui.internal.handlers.CloseAllPerspectivesHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.578
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.578
!MESSAGE Conflict for 'org.eclipse.ui.window.customizePerspective':
HandlerActivation(commandId=org.eclipse.ui.window.customizePerspective,
handler=org.eclipse.ui.internal.handlers.EditActionSetsHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.579
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.579
!MESSAGE Conflict for 'org.eclipse.ui.window.closePerspective':
HandlerActivation(commandId=org.eclipse.ui.window.closePerspective,
handler=org.eclipse.ui.internal.handlers.ClosePerspectiveHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.580
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.580
!MESSAGE Conflict for 'org.eclipse.ui.window.openEditorDropDown':
HandlerActivation(commandId=org.eclipse.ui.window.openEditorDropDown,
handler=org.eclipse.ui.internal.WorkbookEditorsHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.581
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.581
!MESSAGE Conflict for 'org.eclipse.ui.window.newEditor':
HandlerActivation(commandId=org.eclipse.ui.window.newEditor,
handler=org.eclipse.ui.internal.handlers.NewEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.582
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2011-06-27 12:10:33.582
!MESSAGE Conflict for 'org.eclipse.ui.window.maximizePart':
HandlerActivation(commandId=org.eclipse.ui.window.maximizePart,
handler=org.eclipse.ui.internal.handlers.MaximizePartHandler,
!ENTRY org.eclipse.ui 4 4 2011-06-27 12:10:33.837
!MESSAGE Could not create color factory.
!ENTRY org.eclipse.ui.workbench 4 0 2011-06-27 12:10:33.841
!MESSAGE org.eclipse.ui.internal.themes.RGBContrastFactory cannot be cast to org.eclipse.ui.themes.IColorFactory
!STACK 0
java.lang.ClassCastException: org.eclipse.ui.internal.themes.RGBContrastFactory cannot be cast to org.eclipse.ui.themes.IColorFactory
at org.eclipse.ui.internal.themes.ThemeRegistryReader.checkColorFactory(ThemeRegistryReader.java:405)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.getColorValue(ThemeRegistryReader.java:183)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readColor(ThemeRegistryReader.java:139)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readElement(ThemeRegistryReader.java:239)
at org.eclipse.ui.internal.registry.RegistryReader.readElements(RegistryReader.java:144)
at org.eclipse.ui.internal.registry.RegistryReader.readExtension(RegistryReader.java:155)
at org.eclipse.ui.internal.registry.RegistryReader.readRegistry(RegistryReader.java:176)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readThemes(ThemeRegistryReader.java:452)
at org.eclipse.ui.internal.WorkbenchPlugin.getThemeRegistry(WorkbenchPlugin.java:697)
at org.eclipse.ui.internal.Workbench$36.runWithException(Workbench.java:1663)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3515)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3164)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
!ENTRY org.eclipse.ui 4 4 2011-06-27 12:10:33.843
!MESSAGE Plugin org.eclipse.rap.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.INACTIVE_TAB_BG_START: Only one of value or defaultMapping may be set.
!ENTRY org.eclipse.ui 4 0 2011-06-27 12:10:35.198
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.CurrentSelectionSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.ui 4 0 2011-06-27 12:10:35.213
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.ActiveShellSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.ui 4 0 2011-06-27 12:10:35.227
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.ActivePartSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.ui 4 0 2011-06-27 12:10:35.229
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.ActionSetSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.ui 4 0 2011-06-27 12:10:35.237
!MESSAGE Source Provider 'org.eclipse.ui.internal.menus.FocusControlSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.ui 4 0 2011-06-27 12:10:35.239
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.MenuSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.ui 4 0 2011-06-27 12:10:35.241
!MESSAGE Source Provider 'org.eclipse.ui.internal.contexts.ActiveContextSourceProvider' should extend AbstractSourceProvider
eclipse.ini:
-vm
/usr/lib/jvm/java-6-sun-1.6.0.24/bin/java
-startup
plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.2.R36x_v20101019_1345
-showsplash
org.eclipse.platform
256m
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-product
openFile
-vmargs
-Djava.library.path=/usr/lib/jni
-server
-XX:+UseConcMarkSweepGC
-XX:+UnlockDiagnosticVMOptions
-XX:+UnsyncloadClass
-Dosgi.classloader.lock=classname
-Dosgi.requiredJavaVersion=1.6
-Declipse.p2.unsignedPolicy=allow
-Xss4m
-Xms256m
-Xmx1024m
configuration/config.ini:
#This configuration file was written by: org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxFwConfigFileParser
#Mon Jun 27 12:14:56 MSD 2011
org.eclipse.update.reconcile=false
eclipse.p2.profile=epp.package.rcp
osgi.instance.area.default=@user.home/workspace
osgi.framework=file\:plugins/org.eclipse.osgi_3.6.2.R36x_v20110210.jar
equinox.use.ds=true
osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar@1\:start
org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.eclipse.equinox.simpleconfigurator/bundles.info
eclipse.product=org.eclipse.epp.package.rcp.product
osgi.splashPath=platform\:/base/plugins/org.eclipse.platform
osgi.framework.extensions=reference\:file\:org.eclipse.osgi.nl_ru_3.6.0.v20101211043401.jar,reference\:file\:org.eclipse.equinox.weaving.hook_1.0.0.v20100503.jar
osgi.bundles.defaultStartLevel=4
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.p2.data.area=@config.dir/../p2/
Any idea what could be causing this?
[Updated on: Mon, 27 June 2011 05:00] Report message to a moderator
| Re: Problem when starting Eclipse [message #689247 is a reply to message #689240] |
Mon, 27 June 2011 04:45   |
ss command from OSGi console gives this result:
WARNING: This console is connected to the current running instance of Eclipse!
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.6.2.R36x_v20110210
Fragments=325, 500
1 ACTIVE org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503
Fragments=402
2 ACTIVE com.ibm.icu_4.2.1.v20100412
3 RESOLVED com.jcraft.jsch_0.1.41.v200903070017
4 RESOLVED javax.servlet_2.5.0.v200910301333
5 RESOLVED javax.servlet.jsp_2.0.0.v200806031607
6 RESOLVED javax.xml_1.3.4.v201005080400
7 RESOLVED javax.xml.bind_2.0.0.v20080604-1500
8 RESOLVED org.apache.ant_1.7.1.v20100518-1145
9 RESOLVED org.apache.commons.codec_1.3.0.v20100518-1140
10 RESOLVED org.apache.commons.el_1.0.0.v201004212143
11 RESOLVED org.apache.commons.httpclient_3.1.0.v201005080502
12 RESOLVED org.apache.commons.lang_2.3.0.v201005080501
13 RESOLVED org.apache.commons.logging_1.0.4.v201005080501
14 RESOLVED org.apache.jasper_5.5.17.v201004212143
15 RESOLVED org.apache.lucene_1.9.1.v20100518-1140
16 RESOLVED org.apache.lucene.analysis_1.9.1.v20100518-1140
17 RESOLVED org.apache.ws.commons.util_1.0.0.v20100518-1135
18 RESOLVED org.apache.xerces_2.9.0.v201005080400
19 RESOLVED org.apache.xml.resolver_1.2.0.v201005080400
20 RESOLVED org.apache.xml.serializer_2.7.1.v201005080400
21 RESOLVED org.apache.xmlrpc_3.0.0.v20100427-1100
22 <<LAZY>> org.eclipse.ant.core_3.2.201.v20110203_r362
Fragments=326
23 <<LAZY>> org.eclipse.ant.launching_1.0.1.v20101020_r362
Fragments=327
24 <<LAZY>> org.eclipse.ant.ui_3.5.0.v20100427
Fragments=328
25 <<LAZY>> org.eclipse.compare_3.5.101.R36x_v20100929-0800
Fragments=330
26 <<LAZY>> org.eclipse.compare.core_3.5.101.R36x_v20100929-0800
Fragments=329
27 <<LAZY>> org.eclipse.core.boot_3.1.200.v20100505
Fragments=331
28 RESOLVED org.eclipse.core.commands_3.6.0.I20100512-1500
Fragments=332
29 ACTIVE org.eclipse.core.contenttype_3.4.100.v20100505-1235
Fragments=333
30 <<LAZY>> org.eclipse.core.databinding_1.3.100.I20100601-0800
Fragments=335
31 RESOLVED org.eclipse.core.databinding.beans_1.2.100.I20100601-0800
Fragments=334
32 ACTIVE org.eclipse.core.databinding.observable_1.3.0.I20100601-0800
Fragments=336
33 <<LAZY>> org.eclipse.core.databinding.property_1.3.0.I20100601-0800
Fragments=337
34 ACTIVE org.eclipse.core.expressions_3.4.200.v20100505
Fragments=338
35 <<LAZY>> org.eclipse.core.externaltools_1.0.1.v20100831_r361
Fragments=339
36 ACTIVE org.eclipse.core.filebuffers_3.5.100.v20100520-0800
Fragments=340
37 ACTIVE org.eclipse.core.filesystem_1.3.1.R36x_v20100727-0745
Fragments=38, 341
38 RESOLVED org.eclipse.core.filesystem.linux.x86_1.4.0.v20100505-1235
Master=37
39 ACTIVE org.eclipse.core.jobs_3.5.1.R36x_v20100824
Fragments=342
40 ACTIVE org.eclipse.core.net_1.2.100.I20100511-0800
Fragments=41, 344
41 RESOLVED org.eclipse.core.net.linux.x86_1.1.100.R36x_v20100825-0800
Master=40
42 ACTIVE org.eclipse.core.resources_3.6.1.R36x_v20110131-1630
Fragments=345
43 ACTIVE org.eclipse.core.runtime_3.6.0.v20100505
Fragments=348
44 ACTIVE org.eclipse.core.runtime.compatibility_3.2.100.v20100505
Fragments=347
45 ACTIVE org.eclipse.core.runtime.compatibility.auth_3.2.200.v20100517
Fragments=346
46 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.3.0.v20100520
Master=120
47 ACTIVE org.eclipse.core.variables_3.2.400.v20100505
Fragments=349
48 <<LAZY>> org.eclipse.cvs_1.0.500.v201102101200
Fragments=350
49 ACTIVE org.eclipse.debug.core_3.6.0.v20100519
Fragments=351
50 ACTIVE org.eclipse.debug.ui_3.6.3.v20101201_r362
Fragments=352
51 <<LAZY>> org.eclipse.draw2d_3.6.2.v20110128-0100
Fragments=353
52 <<LAZY>> org.eclipse.ecf_3.1.0.v20100906-1425
Fragments=59
53 <<LAZY>> org.eclipse.ecf.filetransfer_4.0.0.v20100906-1425
54 <<LAZY>> org.eclipse.ecf.identity_3.1.0.v20100906-1425
55 <<LAZY>> org.eclipse.ecf.provider.filetransfer_3.1.0.v20100906-1425
Fragments=58
56 <<LAZY>> org.eclipse.ecf.provider.filetransfer.httpclient_4.0.0.v20100906-1425
Fragments=57
57 RESOLVED org.eclipse.ecf.provider.filetransfer.httpclient.ssl_1.0.0.v20100906-1425
Master=56
58 RESOLVED org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20100906-1425
Master=55
59 RESOLVED org.eclipse.ecf.ssl_1.0.100.v20100906-1425
Master=52
60 <<LAZY>> org.eclipse.emf.common_2.6.0.v20100914-1218
61 <<LAZY>> org.eclipse.emf.common.ui_2.6.0.v20100914-1218
62 <<LAZY>> org.eclipse.emf.ecore_2.6.1.v20100914-1218
63 <<LAZY>> org.eclipse.emf.ecore.change_2.5.1.v20100907-1643
64 <<LAZY>> org.eclipse.emf.ecore.edit_2.6.0.v20100914-1218
65 <<LAZY>> org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846
66 <<LAZY>> org.eclipse.emf.edit_2.6.0.v20100914-1218
67 <<LAZY>> org.eclipse.emf.edit.ui_2.6.0.v20100914-1218
68 RESOLVED org.eclipse.epp.mpc.core_1.0.0.v20100826-2143
69 RESOLVED org.eclipse.epp.mpc.help.ui_1.0.0.v20100826-2143
Fragments=354
70 <<LAZY>> org.eclipse.epp.mpc.ui_1.0.1.v20100826-2143
71 RESOLVED org.eclipse.epp.package.common_1.3.2.20110218-0812
72 RESOLVED org.eclipse.epp.package.rcp_1.3.2.20110218-0812
73 ACTIVE org.eclipse.epp.usagedata.gathering_1.3.1.R201102081640
74 ACTIVE org.eclipse.epp.usagedata.recording_1.3.1.R201102081640
75 <<LAZY>> org.eclipse.epp.usagedata.ui_1.3.1.R201102081640
76 ACTIVE org.eclipse.equinox.app_1.3.1.R36x_v20100803
Fragments=355
77 ACTIVE org.eclipse.equinox.common_3.6.0.v20100503
Fragments=356
78 <<LAZY>> org.eclipse.equinox.concurrent_1.0.100.v20100503
Fragments=357
79 ACTIVE org.eclipse.equinox.ds_1.2.1.R36x_v20100803
Fragments=358
80 ACTIVE org.eclipse.equinox.event_1.2.0.v20100503
Fragments=359
81 <<LAZY>> org.eclipse.equinox.frameworkadmin_2.0.0.v20100503
Fragments=361
82 <<LAZY>> org.eclipse.equinox.frameworkadmin.equinox_1.0.200.v20100505
Fragments=360
83 <<LAZY>> org.eclipse.equinox.http.jetty_2.0.0.v20100503
84 RESOLVED org.eclipse.equinox.http.registry_1.1.1.R36x_v20101103
Fragments=362
85 <<LAZY>> org.eclipse.equinox.http.servlet_1.1.0.v20100503
Fragments=363
86 <<LAZY>> org.eclipse.equinox.jsp.jasper_1.0.201.R36x_v20101103
Fragments=364
87 <<LAZY>> org.eclipse.equinox.jsp.jasper.registry_1.0.200.v20100503
Fragments=365
88 RESOLVED org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400
Fragments=89, 367
89 RESOLVED org.eclipse.equinox.launcher.gtk.linux.x86_1.1.2.R36x_v20101019_1345
Master=88
90 <<LAZY>> org.eclipse.equinox.p2.artifact.repository_1.1.1.R36x_v20100901
Fragments=368
91 <<LAZY>> org.eclipse.equinox.p2.console_1.0.200.v20100601
Fragments=369
92 ACTIVE org.eclipse.equinox.p2.core_2.0.3.R36x_v20110111
Fragments=370
93 <<LAZY>> org.eclipse.equinox.p2.director_2.0.3.R36x_v20101117-1018
Fragments=372
94 <<LAZY>> org.eclipse.equinox.p2.director.app_1.0.201.R36x_v20100823
Fragments=371
95 ACTIVE org.eclipse.equinox.p2.directorywatcher_1.0.203.R36x_v20101220
Fragments=373
96 RESOLVED org.eclipse.equinox.p2.discovery_1.0.0.v20100503
Fragments=375
97 <<LAZY>> org.eclipse.equinox.p2.discovery.compatibility_1.0.1.v20110204-1323
Fragments=374
98 ACTIVE org.eclipse.equinox.p2.engine_2.0.1.R36x_v20110201
Fragments=376
99 <<LAZY>> org.eclipse.equinox.p2.extensionlocation_1.2.0.v20100518
Fragments=377
100 <<LAZY>> org.eclipse.equinox.p2.garbagecollector_1.0.100.v20100503
Fragments=378
101 RESOLVED org.eclipse.equinox.p2.jarprocessor_1.0.200.v20100503a
Fragments=379
102 ACTIVE org.eclipse.equinox.p2.metadata_2.0.1.R36x_v20101202
Fragments=381
103 <<LAZY>> org.eclipse.equinox.p2.metadata.generator_1.0.202.R36x_v20101208-1400
Fragments=380
104 ACTIVE org.eclipse.equinox.p2.metadata.repository_1.1.0.v20100513
Fragments=382
105 ACTIVE org.eclipse.equinox.p2.operations_2.0.0.v20100510
Fragments=383
106 <<LAZY>> org.eclipse.equinox.p2.publisher_1.1.2.v20100824-2220
Fragments=384
107 <<LAZY>> org.eclipse.equinox.p2.ql_2.0.0.v20100503a
Fragments=385
108 ACTIVE org.eclipse.equinox.p2.reconciler.dropins_1.1.2.R36x_v20110114
Fragments=386
109 ACTIVE org.eclipse.equinox.p2.repository_2.0.2.R36x_v20110111-1500
Fragments=387
110 <<LAZY>> org.eclipse.equinox.p2.repository.tools_2.0.1.R36x_v20100823
Fragments=388
111 <<LAZY>> org.eclipse.equinox.p2.touchpoint.eclipse_2.0.3.R36x_v20101202
Fragments=389
112 <<LAZY>> org.eclipse.equinox.p2.touchpoint.natives_1.0.201.R36x_v20110111
Fragments=390
113 <<LAZY>> org.eclipse.equinox.p2.ui_2.0.0.v20100518
Fragments=392
114 RESOLVED org.eclipse.equinox.p2.ui.discovery_1.0.0.v20100519
Fragments=391
115 <<LAZY>> org.eclipse.equinox.p2.ui.sdk_1.0.100.v20100513
Fragments=393
116 ACTIVE org.eclipse.equinox.p2.ui.sdk.scheduler_1.0.0.v20100507-1815
Fragments=394
117 ACTIVE org.eclipse.equinox.p2.updatechecker_1.1.101.R36x_v20100823
Fragments=395
118 <<LAZY>> org.eclipse.equinox.p2.updatesite_1.0.201.R36x_v20100823
Fragments=396
119 ACTIVE org.eclipse.equinox.preferences_3.3.0.v20100503
Fragments=397
120 ACTIVE org.eclipse.equinox.registry_3.5.0.v20100503
Fragments=46, 398
121 ACTIVE org.eclipse.equinox.security_1.0.200.v20100503
Fragments=399
122 <<LAZY>> org.eclipse.equinox.security.ui_1.0.200.v20100503
Fragments=400
123 <<LAZY>> org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20100503
Fragments=401
124 ACTIVE org.eclipse.equinox.util_1.0.200.v20100503
Fragments=403
125 <<LAZY>> org.eclipse.gef_3.6.2.v20110110-2020
Fragments=404
126 ACTIVE org.eclipse.help_3.5.0.v20100524
Fragments=407
127 <<LAZY>> org.eclipse.help.appserver_3.1.400.v20100427
Fragments=405
128 <<LAZY>> org.eclipse.help.base_3.5.3.v201102101200
Fragments=406
129 <<LAZY>> org.eclipse.help.ui_3.5.3.r36_20101116
Fragments=408
130 <<LAZY>> org.eclipse.help.webapp_3.5.3.r36_20101130
Fragments=409
131 RESOLVED org.eclipse.jdt_3.6.1.v201102101200
Fragments=423
132 <<LAZY>> org.eclipse.jdt.apt.core_3.3.402.R36_v20110120-1000
Fragments=410
133 <<LAZY>> org.eclipse.jdt.apt.pluggable.core_1.0.301.R36_v20100727-0110
Fragments=411
134 <<LAZY>> org.eclipse.jdt.apt.ui_3.3.300.v20100513-0845
Fragments=412
135 RESOLVED org.eclipse.jdt.compiler.apt_1.0.300.v20100513-0845
Master=137
136 RESOLVED org.eclipse.jdt.compiler.tool_1.0.100.v_A76_R36x
Master=137
137 ACTIVE org.eclipse.jdt.core_3.6.2.v_A76_R36x
Fragments=135, 136, 414
138 ACTIVE org.eclipse.jdt.core.manipulation_1.3.0.v20100520-0800
Fragments=413
139 ACTIVE org.eclipse.jdt.debug_3.6.1.v20100715_r361
Fragments=415
140 ACTIVE org.eclipse.jdt.debug.ui_3.5.2.v20100928a_r362
Fragments=416
141 RESOLVED org.eclipse.jdt.doc.user_3.6.1.r361_v20100721-0800
Fragments=417
142 <<LAZY>> org.eclipse.jdt.junit_3.6.1.r361_v20100825-0800
Fragments=419
143 <<LAZY>> org.eclipse.jdt.junit.core_3.6.1.r361_v20100825-0800
Fragments=418
144 RESOLVED org.eclipse.jdt.junit.runtime_3.4.200.v20100526-0800
Fragments=420
145 RESOLVED org.eclipse.jdt.junit4.runtime_1.1.100.v20100526-0800
Fragments=421
146 ACTIVE org.eclipse.jdt.launching_3.5.200.v20110105_r362
Fragments=422
147 ACTIVE org.eclipse.jdt.ui_3.6.2.r362_v20110203
Fragments=424
148 <<LAZY>> org.eclipse.jem.util_2.1.3.v201012070000
149 ACTIVE org.eclipse.jface_3.6.2.M20110210-1200
Fragments=426
150 RESOLVED org.eclipse.jface.databinding_1.4.0.I20100601-0800
Fragments=425
151 RESOLVED org.eclipse.jface.text_3.6.1.r361_v20100825-0800
Fragments=427
152 ACTIVE org.eclipse.jsch.core_1.1.200.I20100505-1245
Fragments=428
153 <<LAZY>> org.eclipse.jsch.ui_1.1.300.I20100505-1245
Fragments=429
154 <<LAZY>> org.eclipse.ltk.core.refactoring_3.5.101.r362_v20101117-0800
Fragments=430
155 <<LAZY>> org.eclipse.ltk.ui.refactoring_3.5.0.v20100526-0800
Fragments=431
156 RESOLVED org.eclipse.mylyn_3.4.0.v20110131-0200-e3x
157 ACTIVE org.eclipse.mylyn.bugzilla.core_3.4.2.v20100902-0100-e3x
158 RESOLVED org.eclipse.mylyn.bugzilla.ide_3.4.1.v20110131-0100-e3x
159 ACTIVE org.eclipse.mylyn.bugzilla.ui_3.4.3.v20110131-0100-e3x
160 RESOLVED org.eclipse.mylyn.commons.core_3.4.0.v20100608-0100-e3x
161 ACTIVE org.eclipse.mylyn.commons.net_3.4.1.v20100625-2100-e3x
162 ACTIVE org.eclipse.mylyn.commons.ui_3.4.0.v20100608-0100-e3x
163 <<LAZY>> org.eclipse.mylyn.commons.xmlrpc_3.4.0.v20100608-0100-e3x
164 ACTIVE org.eclipse.mylyn.context.core_3.4.1.v20100909-0100-e3x
165 ACTIVE org.eclipse.mylyn.context.ui_3.4.2.v20110131-0100-e3x
166 RESOLVED org.eclipse.mylyn.discovery.core_3.4.0.v20110131-0100-e3x
167 RESOLVED org.eclipse.mylyn.discovery.ui_3.4.0.v20110131-0100-e3x
168 <<LAZY>> org.eclipse.mylyn.help.ui_3.4.2.v20110131-0100-e3x
169 <<LAZY>> org.eclipse.mylyn.ide.ant_3.4.0.v20100608-0100-e3x
170 <<LAZY>> org.eclipse.mylyn.ide.ui_3.4.0.v20100608-0100-e3x
171 <<LAZY>> org.eclipse.mylyn.java.tasks_3.4.0.v20100608-0100-e3x
172 <<LAZY>> org.eclipse.mylyn.java.ui_3.4.0.v20100608-0100-e3x
173 RESOLVED org.eclipse.mylyn.monitor.core_3.4.0.v20100608-0100-e3x
174 ACTIVE org.eclipse.mylyn.monitor.ui_3.4.1.v20110131-0100-e3x
175 <<LAZY>> org.eclipse.mylyn.pde.ui_3.4.0.v20100608-0100-e3x
176 <<LAZY>> org.eclipse.mylyn.resources.ui_3.4.1.v20100909-0100-e3x
177 <<LAZY>> org.eclipse.mylyn.tasks.bugs_3.4.1.v20100823-0100-e3x
178 RESOLVED org.eclipse.mylyn.tasks.core_3.4.2.v20110131-0300-e3x
179 RESOLVED org.eclipse.mylyn.tasks.search_3.4.0.v20100608-0100-e3x
180 ACTIVE org.eclipse.mylyn.tasks.ui_3.4.3.v20110131-0100-e3x
181 RESOLVED org.eclipse.mylyn.team.cvs_3.4.2.v20110131-0100-e3x
182 ACTIVE org.eclipse.mylyn.team.ui_3.4.3.v20110131-0100-e3x
183 RESOLVED org.eclipse.mylyn.wikitext.confluence.core_1.3.0.v20100608-0100-e3x
184 RESOLVED org.eclipse.mylyn.wikitext.confluence.ui_1.3.0.v20100608-0100-e3x
185 <<LAZY>> org.eclipse.mylyn.wikitext.core_1.3.1.v20100823-0100-e3x
186 RESOLVED org.eclipse.mylyn.wikitext.help.ui_1.3.0.v20100608-0100-e3x
187 RESOLVED org.eclipse.mylyn.wikitext.mediawiki.core_1.3.0.v20100608-0100-e3x
188 RESOLVED org.eclipse.mylyn.wikitext.mediawiki.ui_1.3.0.v20100608-0100-e3x
189 <<LAZY>> org.eclipse.mylyn.wikitext.tasks.ui_1.3.1.v20100823-0100-e3x
190 RESOLVED org.eclipse.mylyn.wikitext.textile.core_1.3.0.v20100608-0100-e3x
191 RESOLVED org.eclipse.mylyn.wikitext.textile.ui_1.3.0.v20100608-0100-e3x
192 RESOLVED org.eclipse.mylyn.wikitext.tracwiki.core_1.3.0.v20100608-0100-e3x
193 RESOLVED org.eclipse.mylyn.wikitext.tracwiki.ui_1.3.0.v20100608-0100-e3x
194 RESOLVED org.eclipse.mylyn.wikitext.twiki.core_1.3.0.v20100608-0100-e3x
195 RESOLVED org.eclipse.mylyn.wikitext.twiki.ui_1.3.0.v20100608-0100-e3x
196 <<LAZY>> org.eclipse.mylyn.wikitext.ui_1.3.0.v20100608-0100-e3x
197 RESOLVED org.eclipse.osgi.services_3.2.100.v20100503
Fragments=432
198 RESOLVED org.eclipse.osgi.util_3.2.100.v20100503
Fragments=433
199 RESOLVED org.eclipse.pde_3.6.1.v201102101200
Fragments=443
200 <<LAZY>> org.eclipse.pde.api.tools_1.0.202.v20100820_r361
Fragments=434
201 <<LAZY>> org.eclipse.pde.api.tools.ui_1.0.201.v20100820_r361
Fragments=435
202 <<LAZY>> org.eclipse.pde.build_3.6.2.R36x_20110203
Fragments=436
203 <<LAZY>> org.eclipse.pde.core_3.6.2.v20110210_r362
Fragments=437
204 RESOLVED org.eclipse.pde.doc.user_3.6.2.v20101118_r362
Fragments=438
205 <<LAZY>> org.eclipse.pde.ds.core_1.0.100.v20100601
Fragments=439
206 <<LAZY>> org.eclipse.pde.ds.ui_1.0.100.v20100601
Fragments=440
207 RESOLVED org.eclipse.pde.junit.runtime_3.4.100.v20100601
Fragments=441
208 ACTIVE org.eclipse.pde.launching_3.6.0.v20100601
Fragments=442
209 <<LAZY>> org.eclipse.pde.runtime_3.4.200.v20100601
Fragments=444
210 <<LAZY>> org.eclipse.pde.ua.core_1.0.100.v20100504
Fragments=445
211 <<LAZY>> org.eclipse.pde.ua.ui_1.0.100.v20100504
Fragments=446
212 ACTIVE org.eclipse.pde.ui_3.6.1.v20110210_r362
Fragments=447
213 <<LAZY>> org.eclipse.pde.ui.templates_3.4.200.v20100601
Fragments=448
214 RESOLVED org.eclipse.platform_3.6.2.v201102101200
Fragments=451
215 RESOLVED org.eclipse.platform.doc.isv_3.6.2.r362_v20110111
Fragments=449
216 RESOLVED org.eclipse.platform.doc.user_3.6.2.r362_v20101117-0800
Fragments=450
217 RESOLVED org.eclipse.rap.help_1.3.2.20110216-1041
218 <<LAZY>> org.eclipse.rap.ui.intro_1.3.2.20110216-1041
Fragments=460
219 <<LAZY>> org.eclipse.rap.ui.launch_1.3.2.20110216-1041
Fragments=461
220 RESOLVED org.eclipse.rap.ui.templates_1.3.2.20110216-1041
Fragments=463
221 <<LAZY>> org.eclipse.rcp_3.6.0.v201102101200
Fragments=466
222 <<LAZY>> org.eclipse.search_3.6.0.v20100520-0800
Fragments=467
223 RESOLVED org.eclipse.swt_3.6.2.v3659c
Fragments=224, 468
224 RESOLVED org.eclipse.swt.gtk.linux.x86_3.6.2.v3659b
Master=223
225 ACTIVE org.eclipse.team.core_3.5.101.R36x_v20110203-1036
Fragments=469
226 ACTIVE org.eclipse.team.cvs.core_3.3.301.R36x_v20110119-0815
Fragments=470
227 <<LAZY>> org.eclipse.team.cvs.ssh2_3.2.300.I20100526-0800
Fragments=471
228 ACTIVE org.eclipse.team.cvs.ui_3.3.302.R36x_v20110203-1036
Fragments=472
229 ACTIVE org.eclipse.team.ui_3.5.102.R36x_v20110203-1036
Fragments=473
230 RESOLVED org.eclipse.text_3.5.0.v20100601-1300
Fragments=474
231 ACTIVE org.eclipse.ui_3.6.2.M20110203-1100
Fragments=488
232 <<LAZY>> org.eclipse.ui.browser_3.3.1.r36_20101216
Fragments=475
233 <<LAZY>> org.eclipse.ui.cheatsheets_3.4.0.v20100427
Fragments=476
234 ACTIVE org.eclipse.ui.console_3.5.0.v20100526
Fragments=477
235 ACTIVE org.eclipse.ui.editors_3.6.1.r361_v20100825-0800
Fragments=478
236 <<LAZY>> org.eclipse.ui.externaltools_3.2.0.v20100427
Fragments=479
237 ACTIVE org.eclipse.ui.forms_3.5.2.r36_v20100702
Fragments=480
238 ACTIVE org.eclipse.ui.ide_3.6.2.M20101201-0800
Fragments=482
239 RESOLVED org.eclipse.ui.ide.application_1.0.201.M20100707-0800
Fragments=481
240 <<LAZY>> org.eclipse.ui.intro_3.4.0.v20100427
Fragments=483
241 <<LAZY>> org.eclipse.ui.intro.universal_3.2.402.r36_v20100702
Fragments=484
242 <<LAZY>> org.eclipse.ui.navigator_3.5.0.I20100601-0800
Fragments=485
243 <<LAZY>> org.eclipse.ui.navigator.resources_3.4.202.M20101124-0800
Fragments=486
244 ACTIVE org.eclipse.ui.net_1.2.100.I20100505-1245
Fragments=487
245 <<LAZY>> org.eclipse.ui.presentations.r21_3.2.200.I20100517-1500
Fragments=489
246 ACTIVE org.eclipse.ui.views_3.5.1.M20110202-0800
Fragments=491
247 ACTIVE org.eclipse.ui.views.log_1.0.100.v20110210_r362
Fragments=490
248 <<LAZY>> org.eclipse.ui.views.properties.tabbed_3.5.100.I20100509-0800
Fragments=492
249 ACTIVE org.eclipse.ui.workbench_3.6.2.M20110210-1200
Fragments=250, 493
250 RESOLVED org.eclipse.ui.workbench.compatibility_3.2.100.I20100511-0800
Master=249
251 ACTIVE org.eclipse.ui.workbench.texteditor_3.6.1.r361_v20100714-0800
Fragments=494
252 ACTIVE org.eclipse.update.configurator_3.3.100.v20100512
Fragments=495
253 ACTIVE org.eclipse.update.core_3.2.402.R36x_v20100629
Fragments=254, 496
254 RESOLVED org.eclipse.update.core.linux_3.2.200.v20100512
Master=253
255 ACTIVE org.eclipse.update.scheduler_3.2.300.v20100512
Fragments=497
256 <<LAZY>> org.eclipse.update.ui_3.2.300.v20100512
Fragments=498
257 <<LAZY>> org.eclipse.wst.common.core_1.2.0.v200908252030
258 <<LAZY>> org.eclipse.wst.common.emf_1.2.3.v201012100400
259 <<LAZY>> org.eclipse.wst.common.emfworkbench.integration_1.2.3.v201012020600
260 <<LAZY>> org.eclipse.wst.common.environment_1.0.400.v200912181832
261 <<LAZY>> org.eclipse.wst.common.frameworks_1.2.0.v201003040800
262 <<LAZY>> org.eclipse.wst.common.frameworks.ui_1.2.0.v201004080500
263 <<LAZY>> org.eclipse.wst.common.infopop_1.0.300.v201004280700
264 <<LAZY>> org.eclipse.wst.common.modulecore_1.2.5.v201101270100
265 <<LAZY>> org.eclipse.wst.common.modulecore.ui_1.0.4.v201101101700
266 <<LAZY>> org.eclipse.wst.common.project.facet.core_1.4.102.v201008170019
267 <<LAZY>> org.eclipse.wst.common.snippets_1.2.2.v201101130441
268 <<LAZY>> org.eclipse.wst.common.ui_1.1.500.v200911190730
269 <<LAZY>> org.eclipse.wst.common.uriresolver_1.1.401.v201004280700
270 <<LAZY>> org.eclipse.wst.dtd.core_1.1.401.v201101122255
271 <<LAZY>> org.eclipse.wst.dtd.ui_1.0.500.v201004290328
272 RESOLVED org.eclipse.wst.dtd.ui.infopop_1.0.300.v200805140200
273 RESOLVED org.eclipse.wst.dtdeditor.doc.user_1.0.600.v201005192212
274 <<LAZY>> org.eclipse.wst.internet.cache_1.0.400.v201004280700
275 <<LAZY>> org.eclipse.wst.server.core_1.1.206.v20110110
276 <<LAZY>> org.eclipse.wst.sse.core_1.1.504.v201102160550
277 RESOLVED org.eclipse.wst.sse.doc.user_1.1.100.v201005192212
278 <<LAZY>> org.eclipse.wst.sse.ui_1.2.3.v201102102045
279 RESOLVED org.eclipse.wst.sse.ui.infopop_1.0.300.v201004150328
280 RESOLVED org.eclipse.wst.standard.schemas_1.0.300.v201004110600
281 <<LAZY>> org.eclipse.wst.validation_1.2.201.v201101270100
282 RESOLVED org.eclipse.wst.validation.infopop_1.0.300.v200806041506
283 <<LAZY>> org.eclipse.wst.validation.ui_1.2.204.v201004150700
284 <<LAZY>> org.eclipse.wst.xml.core_1.1.503.v201102102045
285 <<LAZY>> org.eclipse.wst.xml.ui_1.1.103.v201101122108
286 RESOLVED org.eclipse.wst.xml.ui.infopop_1.0.400.v201004292007
287 RESOLVED org.eclipse.wst.xmleditor.doc.user_1.0.700.v201005192212
288 <<LAZY>> org.eclipse.wst.xsd.core_1.1.503.v201011121919
289 <<LAZY>> org.eclipse.wst.xsd.ui_1.2.304.v201101251958
290 RESOLVED org.eclipse.wst.xsdeditor.doc.user_1.0.800.v201005192212
291 <<LAZY>> org.eclipse.xsd_2.6.0.v20100914-1218
292 <<LAZY>> org.eclipse.xsd.edit_2.6.0.v20100914-1218
293 <<LAZY>> org.hamcrest.core_1.1.0.v20090501071000
294 RESOLVED org.junit_3.8.2.v3_8_2_v20100427-1100
295 RESOLVED org.junit_4.8.1.v4_8_1_v20100427-1100
296 RESOLVED org.junit4_4.8.1.v20100525
Fragments=499
297 RESOLVED org.mortbay.jetty.server_6.1.23.v201004211559
298 RESOLVED org.mortbay.jetty.util_6.1.23.v201004211559
299 RESOLVED org.objectweb.asm_3.2.0.v200909071300
300 RESOLVED org.sat4j.core_2.2.0.v20100429
301 RESOLVED org.sat4j.pb_2.2.0.v20100429
303 <<LAZY>> com.collabnet.subversion.merge_2.2.4
304 <<LAZY>> com.sun.jna_3.2.7
314 ACTIVE org.tigris.subversion.clientadapter_1.6.12
315 <<LAZY>> org.tigris.subversion.clientadapter.javahl_1.6.17
316 <<LAZY>> org.tigris.subversion.clientadapter.svnkit_1.6.15
317 ACTIVE org.tigris.subversion.subclipse.core_1.6.18
318 RESOLVED org.tigris.subversion.subclipse.doc_1.3.0
319 <<LAZY>> org.tigris.subversion.subclipse.graph_1.0.9
320 ACTIVE org.tigris.subversion.subclipse.mylyn_3.0.0
321 ACTIVE org.tigris.subversion.subclipse.tools.usage_1.0.1
322 <<LAZY>> org.tigris.subversion.subclipse.ui_1.6.18
323 <<LAZY>> org.tmatesoft.svnkit_1.3.5.7406
325 RESOLVED org.eclipse.osgi.nl_ru_3.6.0.v20101211043401
Master=0
326 RESOLVED org.eclipse.ant.core.nl_ru_3.6.0.v20101211043401
Master=22
327 RESOLVED org.eclipse.ant.launching.nl_ru_3.6.0.v20101211043401
Master=23
328 RESOLVED org.eclipse.ant.ui.nl_ru_3.6.0.v20101211043401
Master=24
329 RESOLVED org.eclipse.compare.core.nl_ru_3.6.0.v20101211043401
Master=26
330 RESOLVED org.eclipse.compare.nl_ru_3.6.0.v20101211043401
Master=25
331 RESOLVED org.eclipse.core.boot.nl_ru_3.6.0.v20101211043401
Master=27
332 RESOLVED org.eclipse.core.commands.nl_ru_3.6.0.v20101211043401
Master=28
333 RESOLVED org.eclipse.core.contenttype.nl_ru_3.6.0.v20101211043401
Master=29
334 RESOLVED org.eclipse.core.databinding.beans.nl_ru_3.6.0.v20101211043401
Master=31
335 RESOLVED org.eclipse.core.databinding.nl_ru_3.6.0.v20101211043401
Master=30
336 RESOLVED org.eclipse.core.databinding.observable.nl_ru_3.6.0.v20101211043401
Master=32
337 RESOLVED org.eclipse.core.databinding.property.nl_ru_3.6.0.v20101211043401
Master=33
338 RESOLVED org.eclipse.core.expressions.nl_ru_3.6.0.v20101211043401
Master=34
339 RESOLVED org.eclipse.core.externaltools.nl_ru_3.6.0.v20101211043401
Master=35
340 RESOLVED org.eclipse.core.filebuffers.nl_ru_3.6.0.v20101211043401
Master=36
341 RESOLVED org.eclipse.core.filesystem.nl_ru_3.6.0.v20101211043401
Master=37
342 RESOLVED org.eclipse.core.jobs.nl_ru_3.6.0.v20101211043401
Master=39
343 INSTALLED org.eclipse.core.net.linux.x86.nl_ru_3.6.0.v20101211043401
344 RESOLVED org.eclipse.core.net.nl_ru_3.6.0.v20101211043401
Master=40
345 RESOLVED org.eclipse.core.resources.nl_ru_3.6.0.v20101211043401
Master=42
346 RESOLVED org.eclipse.core.runtime.compatibility.auth.nl_ru_3.6.0.v20101211043401
Master=45
347 RESOLVED org.eclipse.core.runtime.compatibility.nl_ru_3.6.0.v20101211043401
Master=44
348 RESOLVED org.eclipse.core.runtime.nl_ru_3.6.0.v20101211043401
Master=43
349 RESOLVED org.eclipse.core.variables.nl_ru_3.6.0.v20101211043401
Master=47
350 RESOLVED org.eclipse.cvs.nl_ru_3.6.0.v20101211043401
Master=48
351 RESOLVED org.eclipse.debug.core.nl_ru_3.6.0.v20101211043401
Master=49
352 RESOLVED org.eclipse.debug.ui.nl_ru_3.6.0.v20101211043401
Master=50
353 RESOLVED org.eclipse.draw2d.nl_ru_3.6.0.v20101211043401
Master=51
354 RESOLVED org.eclipse.epp.mpc.help.ui.nl_ru_3.6.0.v20101211043401
Master=69
355 RESOLVED org.eclipse.equinox.app.nl_ru_3.6.0.v20101211043401
Master=76
356 RESOLVED org.eclipse.equinox.common.nl_ru_3.6.0.v20101211043401
Master=77
357 RESOLVED org.eclipse.equinox.concurrent.nl_ru_3.6.0.v20101211043401
Master=78
358 RESOLVED org.eclipse.equinox.ds.nl_ru_3.6.0.v20101211043401
Master=79
359 RESOLVED org.eclipse.equinox.event.nl_ru_3.6.0.v20101211043401
Master=80
360 RESOLVED org.eclipse.equinox.frameworkadmin.equinox.nl_ru_3.6.0.v20101211043401
Master=82
361 RESOLVED org.eclipse.equinox.frameworkadmin.nl_ru_3.6.0.v20101211043401
Master=81
362 RESOLVED org.eclipse.equinox.http.registry.nl_ru_3.6.0.v20101211043401
Master=84
363 RESOLVED org.eclipse.equinox.http.servlet.nl_ru_3.6.0.v20101211043401
Master=85
364 RESOLVED org.eclipse.equinox.jsp.jasper.nl_ru_3.6.0.v20101211043401
Master=86
365 RESOLVED org.eclipse.equinox.jsp.jasper.registry.nl_ru_3.6.0.v20101211043401
Master=87
366 INSTALLED org.eclipse.equinox.launcher.gtk.linux.x86.nl_ru_3.6.0.v20101211043401
367 RESOLVED org.eclipse.equinox.launcher.nl_ru_3.6.0.v20101211043401
Master=88
368 RESOLVED org.eclipse.equinox.p2.artifact.repository.nl_ru_3.6.0.v20101211043401
Master=90
369 RESOLVED org.eclipse.equinox.p2.console.nl_ru_3.6.0.v20101211043401
Master=91
370 RESOLVED org.eclipse.equinox.p2.core.nl_ru_3.6.0.v20101211043401
Master=92
371 RESOLVED org.eclipse.equinox.p2.director.app.nl_ru_3.6.0.v20101211043401
Master=94
372 RESOLVED org.eclipse.equinox.p2.director.nl_ru_3.6.0.v20101211043401
Master=93
373 RESOLVED org.eclipse.equinox.p2.directorywatcher.nl_ru_3.6.0.v20101211043401
Master=95
374 RESOLVED org.eclipse.equinox.p2.discovery.compatibility.nl_ru_3.6.0.v20101211043401
Master=97
375 RESOLVED org.eclipse.equinox.p2.discovery.nl_ru_3.6.0.v20101211043401
Master=96
376 RESOLVED org.eclipse.equinox.p2.engine.nl_ru_3.6.0.v20101211043401
Master=98
377 RESOLVED org.eclipse.equinox.p2.extensionlocation.nl_ru_3.6.0.v20101211043401
Master=99
378 RESOLVED org.eclipse.equinox.p2.garbagecollector.nl_ru_3.6.0.v20101211043401
Master=100
379 RESOLVED org.eclipse.equinox.p2.jarprocessor.nl_ru_3.6.0.v20101211043401
Master=101
380 RESOLVED org.eclipse.equinox.p2.metadata.generator.nl_ru_3.6.0.v20101211043401
Master=103
381 RESOLVED org.eclipse.equinox.p2.metadata.nl_ru_3.6.0.v20101211043401
Master=102
382 RESOLVED org.eclipse.equinox.p2.metadata.repository.nl_ru_3.6.0.v20101211043401
Master=104
383 RESOLVED org.eclipse.equinox.p2.operations.nl_ru_3.6.0.v20101211043401
Master=105
384 RESOLVED org.eclipse.equinox.p2.publisher.nl_ru_3.6.0.v20101211043401
Master=106
385 RESOLVED org.eclipse.equinox.p2.ql.nl_ru_3.6.0.v20101211043401
Master=107
386 RESOLVED org.eclipse.equinox.p2.reconciler.dropins.nl_ru_3.6.0.v20101211043401
Master=108
387 RESOLVED org.eclipse.equinox.p2.repository.nl_ru_3.6.0.v20101211043401
Master=109
388 RESOLVED org.eclipse.equinox.p2.repository.tools.nl_ru_3.6.0.v20101211043401
Master=110
389 RESOLVED org.eclipse.equinox.p2.touchpoint.eclipse.nl_ru_3.6.0.v20101211043401
Master=111
390 RESOLVED org.eclipse.equinox.p2.touchpoint.natives.nl_ru_3.6.0.v20101211043401
Master=112
391 RESOLVED org.eclipse.equinox.p2.ui.discovery.nl_ru_3.6.0.v20101211043401
Master=114
392 RESOLVED org.eclipse.equinox.p2.ui.nl_ru_3.6.0.v20101211043401
Master=113
393 RESOLVED org.eclipse.equinox.p2.ui.sdk.nl_ru_3.6.0.v20101211043401
Master=115
394 RESOLVED org.eclipse.equinox.p2.ui.sdk.scheduler.nl_ru_3.6.0.v20101211043401
Master=116
395 RESOLVED org.eclipse.equinox.p2.updatechecker.nl_ru_3.6.0.v20101211043401
Master=117
396 RESOLVED org.eclipse.equinox.p2.updatesite.nl_ru_3.6.0.v20101211043401
Master=118
397 RESOLVED org.eclipse.equinox.preferences.nl_ru_3.6.0.v20101211043401
Master=119
398 RESOLVED org.eclipse.equinox.registry.nl_ru_3.6.0.v20101211043401
Master=120
399 RESOLVED org.eclipse.equinox.security.nl_ru_3.6.0.v20101211043401
Master=121
400 RESOLVED org.eclipse.equinox.security.ui.nl_ru_3.6.0.v20101211043401
Master=122
401 RESOLVED org.eclipse.equinox.simpleconfigurator.manipulator.nl_ru_3.6.0.v20101211043401
Master=123
402 RESOLVED org.eclipse.equinox.simpleconfigurator.nl_ru_3.6.0.v20101211043401
Master=1
403 RESOLVED org.eclipse.equinox.util.nl_ru_3.6.0.v20101211043401
Master=124
404 RESOLVED org.eclipse.gef.nl_ru_3.6.0.v20101211043401
Master=125
405 RESOLVED org.eclipse.help.appserver.nl_ru_3.6.0.v20101211043401
Master=127
406 RESOLVED org.eclipse.help.base.nl_ru_3.6.0.v20101211043401
Master=128
407 RESOLVED org.eclipse.help.nl_ru_3.6.0.v20101211043401
Master=126
408 RESOLVED org.eclipse.help.ui.nl_ru_3.6.0.v20101211043401
Master=129
409 RESOLVED org.eclipse.help.webapp.nl_ru_3.6.0.v20101211043401
Master=130
410 RESOLVED org.eclipse.jdt.apt.core.nl_ru_3.6.0.v20101211043401
Master=132
411 RESOLVED org.eclipse.jdt.apt.pluggable.core.nl_ru_3.6.0.v20101211043401
Master=133
412 RESOLVED org.eclipse.jdt.apt.ui.nl_ru_3.6.0.v20101211043401
Master=134
413 RESOLVED org.eclipse.jdt.core.manipulation.nl_ru_3.6.0.v20101211043401
Master=138
414 RESOLVED org.eclipse.jdt.core.nl_ru_3.6.0.v20101211043401
Master=137
415 RESOLVED org.eclipse.jdt.debug.nl_ru_3.6.0.v20101211043401
Master=139
416 RESOLVED org.eclipse.jdt.debug.ui.nl_ru_3.6.0.v20101211043401
Master=140
417 RESOLVED org.eclipse.jdt.doc.user.nl_ru_3.6.0.v20101211043401
Master=141
418 RESOLVED org.eclipse.jdt.junit.core.nl_ru_3.6.0.v20101211043401
Master=143
419 RESOLVED org.eclipse.jdt.junit.nl_ru_3.6.0.v20101211043401
Master=142
420 RESOLVED org.eclipse.jdt.junit.runtime.nl_ru_3.6.0.v20101211043401
Master=144
421 RESOLVED org.eclipse.jdt.junit4.runtime.nl_ru_3.6.0.v20101211043401
Master=145
422 RESOLVED org.eclipse.jdt.launching.nl_ru_3.6.0.v20101211043401
Master=146
423 RESOLVED org.eclipse.jdt.nl_ru_3.6.0.v20101211043401
Master=131
424 RESOLVED org.eclipse.jdt.ui.nl_ru_3.6.0.v20101211043401
Master=147
425 RESOLVED org.eclipse.jface.databinding.nl_ru_3.6.0.v20101211043401
Master=150
426 RESOLVED org.eclipse.jface.nl_ru_3.6.0.v20101211043401
Master=149
427 RESOLVED org.eclipse.jface.text.nl_ru_3.6.0.v20101211043401
Master=151
428 RESOLVED org.eclipse.jsch.core.nl_ru_3.6.0.v20101211043401
Master=152
429 RESOLVED org.eclipse.jsch.ui.nl_ru_3.6.0.v20101211043401
Master=153
430 RESOLVED org.eclipse.ltk.core.refactoring.nl_ru_3.6.0.v20101211043401
Master=154
431 RESOLVED org.eclipse.ltk.ui.refactoring.nl_ru_3.6.0.v20101211043401
Master=155
432 RESOLVED org.eclipse.osgi.services.nl_ru_3.6.0.v20101211043401
Master=197
433 RESOLVED org.eclipse.osgi.util.nl_ru_3.6.0.v20101211043401
Master=198
434 RESOLVED org.eclipse.pde.api.tools.nl_ru_3.6.0.v20101211043401
Master=200
435 RESOLVED org.eclipse.pde.api.tools.ui.nl_ru_3.6.0.v20101211043401
Master=201
436 RESOLVED org.eclipse.pde.build.nl_ru_3.6.0.v20101211043401
Master=202
437 RESOLVED org.eclipse.pde.core.nl_ru_3.6.0.v20101211043401
Master=203
438 RESOLVED org.eclipse.pde.doc.user.nl_ru_3.6.0.v20101211043401
Master=204
439 RESOLVED org.eclipse.pde.ds.core.nl_ru_3.6.0.v20101211043401
Master=205
440 RESOLVED org.eclipse.pde.ds.ui.nl_ru_3.6.0.v20101211043401
Master=206
441 RESOLVED org.eclipse.pde.junit.runtime.nl_ru_3.6.0.v20101211043401
Master=207
442 RESOLVED org.eclipse.pde.launching.nl_ru_3.6.0.v20101211043401
Master=208
443 RESOLVED org.eclipse.pde.nl_ru_3.6.0.v20101211043401
Master=199
444 RESOLVED org.eclipse.pde.runtime.nl_ru_3.6.0.v20101211043401
Master=209
445 RESOLVED org.eclipse.pde.ua.core.nl_ru_3.6.0.v20101211043401
Master=210
446 RESOLVED org.eclipse.pde.ua.ui.nl_ru_3.6.0.v20101211043401
Master=211
447 RESOLVED org.eclipse.pde.ui.nl_ru_3.6.0.v20101211043401
Master=212
448 RESOLVED org.eclipse.pde.ui.templates.nl_ru_3.6.0.v20101211043401
Master=213
449 RESOLVED org.eclipse.platform.doc.isv.nl_ru_3.6.0.v20101211043401
Master=215
450 RESOLVED org.eclipse.platform.doc.user.nl_ru_3.6.0.v20101211043401
Master=216
451 RESOLVED org.eclipse.platform.nl_ru_3.6.0.v20101211043401
Master=214
452 ACTIVE org.eclipse.rap.jface_1.3.2.20110216-1023
Fragments=455
453 RESOLVED org.eclipse.rap.jface.databinding_1.3.2.20110216-1023
Fragments=454
454 RESOLVED org.eclipse.rap.jface.databinding.nl_ru_3.6.0.v20101211043401
Master=453
455 RESOLVED org.eclipse.rap.jface.nl_ru_3.6.0.v20101211043401
Master=452
456 RESOLVED org.eclipse.rap.rwt_1.3.2.20110216-1023
Fragments=457
457 RESOLVED org.eclipse.rap.rwt.nl_ru_3.6.0.v20101211043401
Master=456
458 <<LAZY>> org.eclipse.rap.ui_1.3.2.20110216-1023
Fragments=462
459 INSTALLED org.eclipse.rap.ui.forms.nl_ru_3.6.0.v20101211043401
460 RESOLVED org.eclipse.rap.ui.intro.nl_ru_3.6.0.v20101211043401
Master=218
461 RESOLVED org.eclipse.rap.ui.launch.nl_ru_3.6.0.v20101211043401
Master=219
462 RESOLVED org.eclipse.rap.ui.nl_ru_3.6.0.v20101211043401
Master=458
463 RESOLVED org.eclipse.rap.ui.templates.nl_ru_3.6.0.v20101211043401
Master=220
464 ACTIVE org.eclipse.rap.ui.workbench_1.3.2.20110216-1023
Fragments=465
465 RESOLVED org.eclipse.rap.ui.workbench.nl_ru_3.6.0.v20101211043401
Master=464
466 RESOLVED org.eclipse.rcp.nl_ru_3.6.0.v20101211043401
Master=221
467 RESOLVED org.eclipse.search.nl_ru_3.6.0.v20101211043401
Master=222
468 RESOLVED org.eclipse.swt.nl_ru_3.6.0.v20101211043401
Master=223
469 RESOLVED org.eclipse.team.core.nl_ru_3.6.0.v20101211043401
Master=225
470 RESOLVED org.eclipse.team.cvs.core.nl_ru_3.6.0.v20101211043401
Master=226
471 RESOLVED org.eclipse.team.cvs.ssh2.nl_ru_3.6.0.v20101211043401
Master=227
472 RESOLVED org.eclipse.team.cvs.ui.nl_ru_3.6.0.v20101211043401
Master=228
473 RESOLVED org.eclipse.team.ui.nl_ru_3.6.0.v20101211043401
Master=229
474 RESOLVED org.eclipse.text.nl_ru_3.6.0.v20101211043401
Master=230
475 RESOLVED org.eclipse.ui.browser.nl_ru_3.6.0.v20101211043401
Master=232
476 RESOLVED org.eclipse.ui.cheatsheets.nl_ru_3.6.0.v20101211043401
Master=233
477 RESOLVED org.eclipse.ui.console.nl_ru_3.6.0.v20101211043401
Master=234
478 RESOLVED org.eclipse.ui.editors.nl_ru_3.6.0.v20101211043401
Master=235
479 RESOLVED org.eclipse.ui.externaltools.nl_ru_3.6.0.v20101211043401
Master=236
480 RESOLVED org.eclipse.ui.forms.nl_ru_3.6.0.v20101211043401
Master=237
481 RESOLVED org.eclipse.ui.ide.application.nl_ru_3.6.0.v20101211043401
Master=239
482 RESOLVED org.eclipse.ui.ide.nl_ru_3.6.0.v20101211043401
Master=238
483 RESOLVED org.eclipse.ui.intro.nl_ru_3.6.0.v20101211043401
Master=240
484 RESOLVED org.eclipse.ui.intro.universal.nl_ru_3.6.0.v20101211043401
Master=241
485 RESOLVED org.eclipse.ui.navigator.nl_ru_3.6.0.v20101211043401
Master=242
486 RESOLVED org.eclipse.ui.navigator.resources.nl_ru_3.6.0.v20101211043401
Master=243
487 RESOLVED org.eclipse.ui.net.nl_ru_3.6.0.v20101211043401
Master=244
488 RESOLVED org.eclipse.ui.nl_ru_3.6.0.v20101211043401
Master=231
489 RESOLVED org.eclipse.ui.presentations.r21.nl_ru_3.6.0.v20101211043401
Master=245
490 RESOLVED org.eclipse.ui.views.log.nl_ru_3.6.0.v20101211043401
Master=247
491 RESOLVED org.eclipse.ui.views.nl_ru_3.6.0.v20101211043401
Master=246
492 RESOLVED org.eclipse.ui.views.properties.tabbed.nl_ru_3.6.0.v20101211043401
Master=248
493 RESOLVED org.eclipse.ui.workbench.nl_ru_3.6.0.v20101211043401
Master=249
494 RESOLVED org.eclipse.ui.workbench.texteditor.nl_ru_3.6.0.v20101211043401
Master=251
495 RESOLVED org.eclipse.update.configurator.nl_ru_3.6.0.v20101211043401
Master=252
496 RESOLVED org.eclipse.update.core.nl_ru_3.6.0.v20101211043401
Master=253
497 RESOLVED org.eclipse.update.scheduler.nl_ru_3.6.0.v20101211043401
Master=255
498 RESOLVED org.eclipse.update.ui.nl_ru_3.6.0.v20101211043401
Master=256
499 RESOLVED org.junit4.nl_ru_3.6.0.v20101211043401
Master=296
500 RESOLVED org.eclipse.equinox.weaving.hook_1.0.0.v20100503
Master=0
501 RESOLVED org.aspectj.runtime_1.6.12.20110510084300
502 RESOLVED org.aspectj.weaver_1.6.12.20110510084300
503 ACTIVE org.eclipse.contribution.weaving.jdt_2.1.3.e36x-20110510-1300
504 ACTIVE org.eclipse.equinox.weaving.aspectj_1.0.0.v20100503
505 RESOLVED org.scala-ide.scala.compiler_2.9.0.1
506 RESOLVED org.scala-ide.scala.library_2.9.0.1
507 ACTIVE org.scala-ide.sdt.aspects_2.0.0.201106012217-beta5-29-816aa9f
508 ACTIVE org.scala-ide.sdt.core_2.0.0.201106012217-beta5-29-816aa9f
509 RESOLVED org.scala-refactoring.library_0.3.0.201106012322
510 RESOLVED scalariform_0.1.0.201106012326
osgi>
It seems suspicious that some *.rap.* plugins (452, 464) are active.
Current Time: Wed May 22 14:44:12 EDT 2013
Powered by FUDForum. Page generated in 0.01735 seconds
