Home » Language IDEs » COBOL » CooCox Colink(Free and open ARM Cortex M3 and Cortex M0 embedded development tools)
CooCox Colink [message #675018] Mon, 30 May 2011 00:25 Go to next message
nicole_coocox  is currently offline nicole_coocox
Colink Features:
(I) Free and open
(II) Supports ARM Cortex-M3 devices
(III) Download speed up to 250 KB/sec *
(IV) From 5-pin to 20-pin connector support
(V) Wide target voltage range: 1.2V - 3.3V, up to 5V with optional probe
(VI) No power supply required, powered through USB
(VII) Plug-and-Play installation using standard Windows USB drivers
(VIII)Integrates seamlessly into IAR Embedded Workbench and Keil RealView MDK
* Measured with STM32F103 at 72MHz, 6MHz JTAG speed
Colink support is available in:
CooCox CoIDE
CooCox CoFlash Keil RealView MDK 4.03 or higher
IAR Workbench 5.xx
CooCox Colink is a small ARM Cortex M3 JTAG hardware debugging probe. It directly supports CoIDE and CoFlash, and integrates seamlessly into IAR Embedded Workbench and Keil RealView MDK.
CooCox Colink is open, you can Do It Yourself.
[Updated on: Thu, 23 June 2011 22:14]
Report message to a moderator
Re: CooCox Colink----I find it really great [message #676550 is a reply to message #675018] Sun, 05 June 2011 04:14 Go to previous messageGo to next message
Another useful embedded development tool--CoIDE.
It is a new, free and highly-integrated software development environment for ARM cortex M3 and M0 based microcontrollers, which includes all the tools necessary to develop high-quality software solutions in a timely and cost effective manner. It integrates CoBuilder and CoDebugger for simplicity and ease of use.
Supported Device:Atmel Energy Micro Luminary NXP Nuvoton ST
Features:
Free to use
-Full functional IDE
-Component-oriented development platform
-Internet-based, efficient integration of network resources
-Integrates CoOS
-Peripheral registers
It's really great ,and I'd like to share with you .You can have a try.
[Updated on: Sun, 12 June 2011 20:58]
Re: CooCox Colink----I find it really great [message #688142 is a reply to message #676550] Thu, 23 June 2011 22:37 Go to previous message
CoIDE has been updated now!
CoIDE V1.2.5 6/17/2011[CooCox CoIDE-Improved]
Added: Suppoprted: TI:LM3S2110, LM3S2276, LM3S2965, LM3S2B93, LM3S3748, LM3S3W26, LM3S5749, LM3S5B91LM3S6432, LM3S6610, LM3S6918, LM3S8971, LM3S9792, LM3S9B90, LM3S9L97NXP: LPC1763
Added: Support: Nuvonton original Nu-link, Amontec original JTAGkey(FTDI compatible adapters)
Added: Users can use J-Link GDB program to download and debug program in CoIDE
Modified: Change the manufacter name from Luminary to TI
Modified: Change the html editor used when upload/modify the components
Updated: Update the gcc tools.
Learn more about coocox from http://www.coocox.org/
[Updated on: Thu, 23 June 2011 22:39]
Previous Topic:Forum Closure (Reminder)
Next Topic:Cobol Compiler available in plug-in
Current Time: Tue May 28 05:25:00 EDT 2013
Powered by FUDForum. Page generated in 0.03562 seconds
