Home » Eclipse Projects » EclipseLink » Ignoring oracle sequence
Ignoring oracle sequence [message #686107] Tue, 21 June 2011 14:19 Go to next message
Mauro Flores is currently offline Mauro Flores
Member
I have an entity with the following id configuration:
  @Id
  @Column(name = "NRO_INT_FOO")
  @SequenceGenerator(name = "Foo_SEQ", sequenceName = "ID_FOO_SEQ", allocationSize = 10)
  @GeneratedValue(strategy = GenerationType.SEQUENCE, generator = "Foo_SEQ")
  Long               nroIntFoo;
For some reason the last number of the oracle seguence ID_FOO_SEQ is ignored and sometimes I get an ORA-00001 (unique constraint violated)
Any help is appreciated
Thanks. Mauro.
Re: Ignoring oracle sequence [message #686116 is a reply to message #686107] Tue, 21 June 2011 15:01 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
Is the oracle sequence object incrementing by 10 to match the allocation size you set in the annotation? Try turning logging on to see the SQL that is generated using <property name="eclipselink.logging.level" value="FINEST"/>
Best Regards,
Chris
Previous Topic:eclipselink-orm.xml and Eclipse JPA views
Next Topic:(no subject)
Current Time: Sat May 18 15:43:57 EDT 2013
Powered by FUDForum. Page generated in 0.01778 seconds
