Home » Eclipse Projects » BIRT » Using graphical/chart part of Birt as a plugin like JFreeChart
Using graphical/chart part of Birt as a plugin like JFreeChart [message #184202] Thu, 10 August 2006 10:03 Go to next message
Eclipse User
Originally posted by: guillaume.helle.capgemini.com
i have an Eclipse RCP application and i am using JFreeChart to display my
graphs/charts.
Is it possible to use the graph/chart part of Birt to replace JFreeChart in
my RCP application?
Thanks for your help!
Best regards
Guillaume Helle
Re: Using graphical/chart part of Birt as a plugin like JFreeChart [message #184424 is a reply to message #184202] Sat, 12 August 2006 02:11 Go to previous messageGo to next message
Zhiqiang Qian is currently offline Zhiqiang Qian
Member
Yes, normally you would just need following plugins to use chart:
(required)
org.eclipse.birt.core
org.eclipse.birt.chart.engine
org.eclipse.birt.chart.engine.extension
org.eclipse.birt.chart.device.extension (Swing and Image rendering)
org.eclipse.emf.common
org.eclipse.emf.ecore
org.eclipse.emf.ecore.xmi
(optional)
org.eclipse.birt.chart.device.swt (SWT rendering only)
org.eclipse.birt.chart.device.svg (SVG rendering only)
You could check those chart api examples within the
org.eclipse.birt.chart.examples plugin.
hope this helps
Guillaume Helle wrote:
> Hello,
> graphs/charts.
> my RCP application?
> Best regards
> Guillaume Helle
Re: Using graphical/chart part of Birt as a plugin like JFreeChart [message #184432 is a reply to message #184424] Sat, 12 August 2006 02:14 Go to previous messageGo to next message
Member
Oops, I forgot the following plugins:
com.ibm.icu
org.apache.commons.codec
org.mozilla.rhino
which are also dependencies by chart.
> (required)
> (optional)
> hope this helps
>> Hello,
>> graphs/charts.
>> JFreeChart in
>> my RCP application?
>> Best regards
>> Guillaume Helle
Re: Using graphical/chart part of Birt as a plugin like JFreeChart [message #686001 is a reply to message #184432] Tue, 21 June 2011 07:00 Go to previous messageGo to next message
chinnii  is currently offline chinnii
Dear Zhiqiang Qian,
i have to create RCP PlugIn Application which renders PieChart.
So i have tried with JFreeChart for SWT.
But when i use this in the View Class of RCP Application it not able to create the View and not Creating PieCharts. I did not change the MANIFEST file. i added all the 7 required JARs in to the Build Path.
Could you tell me the Solution .
Thanks & Regards
Kranti Kumar ch
Re: Using graphical/chart part of Birt as a plugin like JFreeChart [message #686002 is a reply to message #184424] Tue, 21 June 2011 07:02 Go to previous message
Dear Helle,
Thanks & Regards
Kranti Kumar ch
Previous Topic:Table footer for every page
Next Topic:chart engine API questions
Current Time: Mon May 20 00:07:01 EDT 2013
Powered by FUDForum. Page generated in 0.01594 seconds
