Home » Eclipse Projects » EclipseLink » Eclipselink version for JBoss EAP 5.1.0
Eclipselink version for JBoss EAP 5.1.0 [message #685328] Fri, 17 June 2011 05:32 Go to next message
ebsemailtest is currently offline ebsemailtest
We dunno which version of Eclipselink should be used for our project.
Server: JBoss EAP 5.1.0
We found the following error when using Eclipselink 1.2.0
property eclipselink.jdbc.user is deprecated, property
javax.persistence.jdbc.user should be used instead.
But as I know javax.persistence.jdbc.user is some kind of stuff in EclipseLink 2.
And does EcpliseLink 1.2.0 fit the JBoss EAP 5.1.0?
Thank you.
Re: Eclipselink version for JBoss EAP 5.1.0 [message #685880 is a reply to message #685328] Mon, 20 June 2011 09:56 Go to previous message
James Sutherland is currently offline James Sutherland
This is just a warning, "eclipselink.jdbc.user" will still work. Support for "javax.persistence.jdbc.user" was added in 1.2, so you could you it as well.
EclipseLink 1.2, or the latest release should work with JBoss EAP 5.1.0. EclipseLink 2.3 still supports for JPA 1.0 and JPA 2.0 containers.
James : Wiki : Book : Blog
Previous Topic:Cache coordination instructions for Glassfish 3.1 and JMS
Next Topic:Maven repository incomplete
Current Time: Sat May 25 09:44:06 EDT 2013
Powered by FUDForum. Page generated in 0.01946 seconds
