| plug-in developer wanted in US [message #675818] |
Wed, 01 June 2011 11:38  |
Pat Rogers Messages: 1 Registered: July 2009 |
Junior Member |
We seek plug-in developers for new functionality and maintenance of existing code in Java for a product supporting Ada. Work to be done largely off-site at your own location with flexible hours, but location in the general Houston area is highly desirable for initial in-person project familiarization and support from co-developers.
Prior Eclipse plug-in development experience is required. Prior knowledge of Ada is of value but is not required as development will be in Java. Prior professional programming experience is extremely valuable, but need not be extensive as long as it is directly applicable. Must work well without extensive supervision.
Eventually would also support existing developers in customer problem report resolution, via email.
This is initially envisioned as an indefinite contracting position but full-time employment is not out of the question.
For consideration please send your resume to gnatbench at classwide dot com
| Re: plug-in developer wanted in US [message #685824 is a reply to message #675818] |
Mon, 20 June 2011 05:47  |
Charu Sharma Messages: 17 Registered: May 2011 Location: Pune |
Junior Member |
I have 2 years experience in Eclipse plug-in and RCP development. I am currently located in Pune.
I have worked on Core java, Object Oriented Programming, UML and BPMN concepts, Design Patterns, XML, EMF, GEF, SWT/JFace, ECF, JDT, JUnit, CDT, and Managed Build System (MBS).
Charu Sharma
Mail ID: sharmacharu08@gmail.com
Phone number: +91 9096323264
FUDForum. Page generated in 0.04052 seconds
