Home » Eclipse Projects » Simultaneous release » Ubuntu Natty: 32 bit JDK in Eclipse Galileo
Ubuntu Natty: 32 bit JDK in Eclipse Galileo [message #684894] Thu, 16 June 2011 08:50
amaunz78  is currently offline amaunz78
I want to install Oracle's JDK (32 bit version) under Ubuntu Natty (64 bit version). While there is a package for JRE (32 bit version) in Ubuntu Natty (ia32-sun-java6-bin), I want a JDK (32 bit version), which I need in Eclipse.
I have been told elsewhere that the Java compiler produces byte code which is same whether I use the 32-bit or 64-bit JDK. Thus the suggestion was to use a 64-bit JDK in Eclipse and the 32-bit JRE to run stuff. How can I do this in Eclipse?
As a side note, I don't want to install manually, if possible, using the Oracle-provided .bin installer.
Previous Topic:Not find spring jar sometime
Next Topic:juno.build contains some old b3aggrcon files
Current Time: Fri May 24 04:02:06 EDT 2013
Powered by FUDForum. Page generated in 0.04599 seconds
