Home » Modeling » Epsilon » Process in-memory EMF model
Process in-memory EMF model [message #683925] Tue, 14 June 2011 12:54 Go to next message
Markus Krallinger is currently offline Markus Krallinger
Hello!
I have my models defined in XText, after reading them from the HD they are stored as normal EMF models. In the next processing step I want to analyse them using EOL programmatically.
How can this be done, since I can just execute EOL on something derived from IModel? In the worst case, I would have to read the model again from the harddisk or implement the whole IModel interface. Are there any other suggestions?
Thanks for the help!
Markus
Re: Process in-memory EMF model [message #684445 is a reply to message #683925] Wed, 15 June 2011 11:18 Go to previous message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Markus,
You can use an InMemoryEmfModel to wrap an existing EMF resource. An example that shows how to do this is available here: https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsilon/trunk/examples/org.eclipse.epsilon.eugenia.examples.friends.callegl (you'll need to check out all the org...friends.* sibling projects to get this to work)
Dimitris
Previous Topic:[Eugenia] FixGMFGen and nullpointerexception
Next Topic:(no subject)
Current Time: Tue May 21 03:55:56 EDT 2013
Powered by FUDForum. Page generated in 0.06961 seconds
