Home » Eclipse Projects » Plugin Development Environment (PDE) » Apply/Revert button not getting enabled in launch configuration tab(Apply/Revert button not getting enabled in launch configuration tab)
Apply/Revert button not getting enabled in launch configuration tab [message #684343] Wed, 15 June 2011 09:09 Go to next message
vinay  is currently offline vinay
I have created an launch configuration tab for a new debug configuration.I have added controls(Text, CheckBox etc) on that tab. But when I enter some data or change data in those controls, the Apply/Revert buttons are not getting enabled.
Would someone please provide me some guidance?
Thanks in advance.
Re: Apply/Revert button not getting enabled in launch configuration tab [message #692574 is a reply to message #684343] Mon, 04 July 2011 14:40 Go to previous messageGo to next message
Paul Glezen is currently offline Paul Glezen
Member
You may want to create your own local instance of a ModifyListener for your configuration
tab like the one below.
private ModifyListener modifyListener = new ModifyListener() {
public void modifyText(ModifyEvent e) {
setDirty(true);
updateLaunchConfigurationDialog();
Add the listener to the important fields on your configuration tab.
Re: Apply/Revert button not getting enabled in launch configuration tab [message #836518 is a reply to message #692574] Wed, 04 April 2012 11:29 Go to previous message
Joel Greenyer is currently offline Joel Greenyer
I'm having the same problem.
I extend the AbstractLaunchConfigurationTab class and do the same.
The Apply and Revert buttons stay deactivated... what could I be missing...?
When I debug, I see that setDirty(true) and updateLaunchConfigurationDialog() are definitely called.
Any idea?
Joel
On 04.07.2011 20:40, Paul Glezen wrote:
> You may want to create your own local instance of a ModifyListener for your configuration tab like the one below.
> setDirty(true);
Previous Topic:Widget disposed when changing perspective
Next Topic:Creating plugin in eclipse
Current Time: Tue May 21 18:02:10 EDT 2013
Powered by FUDForum. Page generated in 0.02607 seconds
