Home » Eclipse Projects » Target Management » How to show only remote files in RSE's remote file selection dialog?
How to show only remote files in RSE's remote file selection dialog? [message #684007] Tue, 14 June 2011 16:54 Go to next message
Samuel Lampa is currently offline Samuel Lampa
I'm using the following code to fire up a Remote File Selection Dizard in RSE, and receive the full path of the selected file:
SystemRemoteFileDialog dialog = new SystemRemoteFileDialog(SystemBasePlugin.getActiveWorkbenchShell());
dialog.open();
Object o = dialog.getSelectedObject();
if (o instanceof IRemoteFile) {
    IRemoteFile file = (IRemoteFile)
    System.out.println("Selected file's abs path: " + file.getAbsolutePath());
} else {
    System.out.println("No valid file selected!");
But, the file selection dialog shows both the local files and the remote ones, as well as a drop-down menu at the top, to select connection; local, or one of the remote hosts. (See image at i.stack.imgur.com/jHQkC.png ).
How can I programmatically hide this drop-down menu, and show only the files for a specific remote connection?
Also, I'd like to have the file tree show only files under a specific directory (e.g. the user's home dir). How can I do that? In the main RSE view, it is possible to do this manually by right-clicking a folder, and selecting "Go Into", but I want to do it programmatically.
Best Regards
// Samuel
[Updated on: Tue, 14 June 2011 17:24]
Report message to a moderator
(no subject) [message #684050 is a reply to message #684007] Tue, 14 June 2011 18:47 Go to previous messageGo to next message
David McKnight is currently offline David McKnight
I sent this on the mailing list too:
You can restrict the connection types available by calling the
setSystemTypes(IRSESystemType[]) API.
If you want to use a specific connection, then you can call this:
setDefaultSystemConnection(<host>, true)
As for showing only files under a specific directory, you'll probably have
to provide your own class that extends SystemRemoteResourceDialog and with
that provide your own input provider (i.e.
ISystemResourceSelectionInputProvider) returns the appropriate system view
roots.
Dave
"Samuel Lampa" <forums-noreply@eclipse.org> wrote in message
news:it8h87$hrt$1@news.eclipse.org...
> I'm using the following code to fire up a RemoteFileSelectionWizard in
> dialog.open();
> IRemoteFile file = (IRemoteFile) System.out.println("Selected file's
> } else {
> ones (There's a drop-down menu at the top, to select connection; local, or
> one of the remote hosts.).
> Best Regards
> // Samuel
Re: (no subject) [message #684210 is a reply to message #684050] Wed, 15 June 2011 04:28 Go to previous message
David McKnight wrote on Tue, 14 June 2011 18:47
Indeed, thanks a lot!
(Strange how I missed that, while scanning the methods ...).
Just for the reference, the complete "snippet" of how I do (except for some additional exception handling):
IHost myHost = null;
ISystemRegistry reg = SystemStartHere.getSystemRegistry();
IHost[] hosts = reg.getHosts();
for (IHost host : hosts) {
    if (host.getAliasName().equals("[host-name-of-my-connection]")) {
        myHost = host;
        break;
dialog.setDefaultSystemConnection(myHost, true);
dialog.open();
    IRemoteFile file = (IRemoteFile) o;
} else {
Best
// Samuel
Previous Topic:RSE (and also Aptana) uploads are forced to sub-folder
Next Topic:RSE vs local project with linked remote files
Current Time: Thu May 23 23:22:32 EDT 2013
Powered by FUDForum. Page generated in 0.01595 seconds
