| Cannot shut down Apache Tomcat 6.0 [message #683702] |
Tue, 14 June 2011 05:21  |
Matei Missing name Messages: 14 Registered: September 2010 |
Junior Member |
I am using Eclipse Helios SR1 and Apache Tomcat 6.0.32.
Tomcat starts just fine, but when I try to stop it / shut it down it creates a new console which terminates its execution quickly in which it doesn't display anything.
Meanwhile Tomcat's console displays the shutdown procedure messages and when it is all done it just hangs, the process isn't killed.
The last lines are usually:
Jun 1, 2011 12:54:56 PM org.apache.coyote.http11.Http11AprProtocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8080
Jun 1, 2011 12:54:56 PM org.apache.coyote.ajp.AjpAprProtocol destroy
INFO: Stopping Coyote AJP/1.3 on ajp-8009
After these Tomcat should have shut down, but it just hangs.
Can anybody please give a solution, or at least a suggestion? And why is the second console created ?
Thank you!
| Re: Cannot shut down Apache Tomcat 6.0 [message #683920 is a reply to message #683702] |
Tue, 14 June 2011 12:29   |
Larry Isaacs Messages: 1261 Registered: July 2009 |
> Thank you!
The second console is to send a "shutdown" request to the shutdown port
of the Tomcat server. This allows Tomcat to perform an controlled
shutdown. However, it is a known behavior of Tomcat that it will wait
*forever* for all webapps to "clean up" before exiting.
Usually this situation occurs when a webapp starts a non-daemon thread
which it fails to terminate when shutdown. It can also occur if the
webapp uses RMI and fails to free all the remote objects at shutdown.
Typically you can see threads are the problem by running in debug mode
and checking the Debug window after shutdown to see what threads are
still running. You may need to pull down the Debug window's "View Menu"
(the one next to Minimize and Maximize icons) and select Java -> Show
System Threads to see the threads that are the cause of the problem.
Normally, after the specified shutdown period, a dialog should appear
asking if you want to terminate the Tomcat server. I don't know why
this would not appear for you.
Larry
FUDForum. Page generated in 0.02084 seconds
