Home » Language IDEs » PDT » Error comparing files(Internal Eclipse Error)
Error comparing files [message #667467] Thu, 28 April 2011 18:20 Go to next message
No real name is currently offline No real name
I have eclipse helios with PDT installed on openSuse 11.4 64-bit OS. When trying to compare two local versions of a file from the history, eclipse breaks. The log file for the session follows. Any help on how to recover would be greatly appreciated.
!SESSION 2011-04-28 17:57:43.275 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0_20
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.php.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.php.product
!ENTRY org.eclipse.ui 4 4 2011-04-28 17:57:54.357
!MESSAGE Could not create view: 'org.eclipse.ui.internal.introview'.
!ENTRY org.eclipse.ui 4 0 2011-04-28 17:58:03.113
!MESSAGE Problems occurred restoring workbench.
!SUBENTRY 1 unknown 0 0 2011-04-28 17:58:03.113
!MESSAGE OK
!MESSAGE OK
!MESSAGE OK
!MESSAGE OK
!SUBENTRY 1 org.eclipse.ui 4 0 2011-04-28 17:58:03.113
!MESSAGE Unable to restore perspective: Workspace - PHP.
!SUBENTRY 2 org.eclipse.ui 0 0 2011-04-28 17:58:03.113
!MESSAGE Problems occurred restoring perspective.
!SUBENTRY 3 org.eclipse.ui 0 0 2011-04-28 17:58:03.113
!MESSAGE
!SUBENTRY 2 unknown 0 0 2011-04-28 17:58:03.113
!MESSAGE OK
!MESSAGE OK
!SUBENTRY 2 unknown 0 0 2011-04-28 17:58:03.114
!MESSAGE OK
!MESSAGE OK
!MESSAGE OK
!MESSAGE OK
!MESSAGE OK
!MESSAGE OK
!MESSAGE OK
!SUBENTRY 2 org.eclipse.ui 4 0 2011-04-28 17:58:03.114
!MESSAGE Could not find view: org.eclipse.ui.internal.introview
!SUBENTRY 1 unknown 0 0 2011-04-28 17:58:03.114
!MESSAGE OK
!ENTRY org.eclipse.ui 4 0 2011-04-28 17:59:02.573
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3515)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3164)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.lang.NullPointerException
at org.eclipse.php.internal.core.format.FormatPreferencesSuppor t.verifyValidity(FormatPreferencesSupport.java:100)
at org.eclipse.php.internal.core.format.FormatPreferencesSuppor t.getIndentationChar(FormatPreferencesSupport.java:89)
at org.eclipse.php.internal.ui.editor.configuration.PHPStructur edTextViewerConfiguration.getIndentPrefixes(PHPStructuredTex tViewerConfiguration.java:448)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.configu re(StructuredTextViewer.java:311)
at org.eclipse.php.internal.ui.compare.MergeSourceViewer.config ure(MergeSourceViewer.java:542)
at org.eclipse.php.internal.ui.compare.TextMergeViewer$Contribu torInfo.internalSetDocument(TextMergeViewer.java:546)
at org.eclipse.php.internal.ui.compare.TextMergeViewer$Contribu torInfo.setDocument(TextMergeViewer.java:434)
at org.eclipse.php.internal.ui.compare.TextMergeViewer.updateCo ntent(TextMergeViewer.java:2569)
at org.eclipse.php.internal.ui.compare.ContentMergeViewer.inter nalRefresh(ContentMergeViewer.java:814)
at org.eclipse.php.internal.ui.compare.ContentMergeViewer.input Changed(ContentMergeViewer.java:704)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:274)
at org.eclipse.compare.CompareViewerSwitchingPane.setInput(Comp areViewerSwitchingPane.java:276)
at org.eclipse.compare.internal.CompareContentViewerSwitchingPa ne.setInput(CompareContentViewerSwitchingPane.java:158)
at org.eclipse.compare.CompareEditorInput.internalSetContentPan eInput(CompareEditorInput.java:844)
at org.eclipse.compare.CompareEditorInput.access$8(CompareEdito rInput.java:842)
at org.eclipse.compare.CompareEditorInput$11.run(CompareEditorI nput.java:778)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.compare.CompareEditorInput.feed1(CompareEditorIn put.java:772)
at org.eclipse.compare.CompareEditorInput.feedInput(CompareEdit orInput.java:750)
at org.eclipse.compare.CompareEditorInput.createContents(Compar eEditorInput.java:554)
at org.eclipse.compare.internal.CompareEditor.createCompareCont rol(CompareEditor.java:456)
at org.eclipse.compare.internal.CompareEditor.access$6(CompareE ditor.java:422)
at org.eclipse.compare.internal.CompareEditor$3.run(CompareEdit or.java:378)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:164)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer. java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
... 23 more
Re: Error comparing files [message #683650 is a reply to message #667467] Tue, 14 June 2011 03:27 Go to previous message
jess  is currently offline jess
Hi!
did you found a solution to your problem, because I have the same error as you.
Previous Topic:Problem with XDebug on Linux
Next Topic:Bad Habbits
Current Time: Wed May 22 20:41:43 EDT 2013
Powered by FUDForum. Page generated in 0.02688 seconds
