Home » Eclipse Projects » EclipseLink » Catching Internal Exceptions
Catching Internal Exceptions [message #683400] Mon, 13 June 2011 13:05 Go to next message
AmFreak Missing name is currently offline AmFreak Missing name
how can i catch Eclipse Link exceptions?
For example if i start my application and the server insn't running i get:
[EL Severe]: Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLNonTransientConnectionException: java.net.ConnectException: Fehler beim Herstellen der Verbindung zum Server localhost am Port 1527. Nachricht: Connection refused: connect.
Error Code: 40000
	at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324)
	at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:319)
	at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138)
	at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
	at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connectInternal(DatasourceAccessor.java:330)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.connectInternal(DatabaseAccessor.java:291)
	at org.eclipse.persistence.internal.databaseaccess.DatasourceAccessor.connect(DatasourceAccessor.java:418)
	at org.eclipse.persistence.sessions.server.ConnectionPool.buildConnection(ConnectionPool.java:167)
	at org.eclipse.persistence.sessions.server.ConnectionPool.startUp(ConnectionPool.java:453)
	at org.eclipse.persistence.sessions.server.ServerSession.connect(ServerSession.java:484)
	at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.login(DatabaseSessionImpl.java:640)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:235)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:394)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getServerSession(EntityManagerFactoryImpl.java:185)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:242)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:230)
	at de.fh.stockgrabber.model.StockGrabberEntityManagerFactory.createEntityManager(StockGrabberEntityManagerFactory.java:104)
	at de.fh.stockgrabber.model.StockGrabberEditorModel.<init>(StockGrabberEditorModel.java:37)
	at de.fh.stockgrabber.project.model.ProjectsModel.<init>(ProjectsModel.java:40)
	at de.fh.stockgrabber.views.MainView.createPartControl(MainView.java:105)
	at org.eclipse.ui.internal.ViewReference.createPartHelper
        [many more]
The code crashes when i try to create the EntityManager:
		try {
			em = StockGrabberEntityManagerFactory.createEntityManager();
			transaction = em.getTransaction();
			transaction.begin();
		} catch (Exception e) {
			System.exit(0);
The Exception is catched (the app exists), but it doesn't stop the output as seen above. So how can i handle this; or can't i cause it's an "Internal Exception"?
Re: Catching Internal Exceptions [message #683429 is a reply to message #683400] Mon, 13 June 2011 13:55 Go to previous messageGo to next message
James Sutherland is currently offline James Sutherland
Do you want to catch the exception, or just not have it logged?
You can turn off logging to not have the error logged, set the log level to OFF.
http://wiki.eclipse.org/EclipseLink/Examples/JPA/Logging
James : Wiki : Book : Blog
(no subject) [message #683443 is a reply to message #683400] Mon, 13 June 2011 13:55 Go to previous messageGo to next message
James is currently offline James
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: (no subject) [message #683575 is a reply to message #683429] Mon, 13 June 2011 22:57 Go to previous message
Sry for the late reply Embarrassed
Im new to this whole database thing, but that was what i was missing.
So thank you, really appreciated!
(no subject) [message #683585 is a reply to message #683429] Mon, 13 June 2011 22:57 Go to previous message
Sry for the late reply :blush:
Previous Topic:How can I get count of distinct left join subquery?
Next Topic:CriteriaBuilder.isEmpty on an ElementCollection vs. JPQL approach
Current Time: Fri May 24 13:06:59 EDT 2013
Powered by FUDForum. Page generated in 0.01695 seconds
