Home » Eclipse Projects » Rich Client Platform (RCP) » compilation of RCP through the command prompt
compilation of RCP through the command prompt [message #683263] Mon, 13 June 2011 07:42 Go to next message
wilsontan81 is currently offline wilsontan81
Hi all,
I was requested to download and build the program from the source code.
Thus, I would like to know, is it possible that to compile a RCP through the command prompt?
Thanks for reply.
Re: compilation of RCP through the command prompt [message #683470 is a reply to message #683263] Mon, 13 June 2011 16:22 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
See the "Building Headless" section of http://www.eclipse.org/articles/Article-PDE-Automation/automation.html
Once you get started, there are lots of examples of using PDE build to build products, just search for them. ex: http://pweclipse.blogspot.com/2010/09/simple-rcp-product-build.html
PW
Re: compilation of RCP through the command prompt [message #683668 is a reply to message #683470] Tue, 14 June 2011 04:08 Go to previous message
thank you very much
Previous Topic:WizardResourceImportPage container validation
Next Topic:Launch a second application instance as new vm process
Current Time: Tue May 21 20:01:51 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
