Home » Modeling » TMF (Xtext) » org.eclipse.xtext.parsetree for xtext 2.0
org.eclipse.xtext.parsetree for xtext 2.0 [message #683222] Mon, 13 June 2011 05:13 Go to next message
Elhamlaoui Mahmoud is currently offline Elhamlaoui Mahmoud
Can i kow where i could get
package from?, i nedd it to Synchronize Xtext and GMF.
thanks in advance
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683232 is a reply to message #683222] Mon, 13 June 2011 05:41 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
Xtext 2.0.0 comes with a brand new org.eclipse.xtext.nodemodel. See Rewritten Node Model
in the docs (chapter Migrating from Xtext 1.0.x to 2.0
~Christian
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683236 is a reply to message #683232] Mon, 13 June 2011 06:09 Go to previous messageGo to next message
Hi Christian,
Where could i found the doc for Xtext 2.0.0 ive found just this http://www.eclipse.org/Xtext/documentation/ for 1.0.1
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683241 is a reply to message #683236] Mon, 13 June 2011 06:19 Go to previous messageGo to next message
hi, if you have installed Xtext 2.0 you can find it in the Help of your eclipse. ~Christian
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683249 is a reply to message #683241] Mon, 13 June 2011 06:59 Go to previous messageGo to next message
Ive done so, but i couldnt find it, I dont know way, but in my eclipse with wtext 1.0.1 the documentation are there, but its not the case with the 2.0
thx in advance
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683252 is a reply to message #683249] Mon, 13 June 2011 07:08 Go to previous messageGo to next message
how did you install Xtext 2.0.0? From the Nightly Update site https://hudson.eclipse.org/hudson/job/Xtext-nightly-HEAD/lastSuccessfulBuild/artifact/xtext.p2.repository you should be able to get the Xtext Documentation Feature.
~Christian
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683292 is a reply to message #683252] Mon, 13 June 2011 08:40 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
On 06/13/2011 01:08 PM, Christian Dietrich wrote:
> ~Christian
by the way, is it better use use
Update site for milestones:
http://download.eclipse.org/modeling/tmf/updates/milestones
or
Update site for nightly builds:
http://download.eclipse.org/modeling/tmf/updates/nightly
at this stage?
thanks
Lore
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683313 is a reply to message #683292] Mon, 13 June 2011 09:54 Go to previous messageGo to next message
since Indigo release will be on June 22th i think it doesn't matter if you use a RC or the Nightlys: For something productive you can wait these 10 days for the final release.
~Christian
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683340 is a reply to message #683252] Mon, 13 June 2011 10:56 Go to previous messageGo to next message
hi Christian,
Its working, i think ive installed with the given updatesite.
thanks again
Re: org.eclipse.xtext.parsetree for xtext 2.0 [message #683387 is a reply to message #683313] Mon, 13 June 2011 12:14 Go to previous message
i Christian
RC3 had no toc.xml, so RC4 is required (RC<3 has 1.0 documentation.)
Ed Willink
On 13/06/2011 14:54, Christian Dietrich wrote:
> ~Christian
Previous Topic:[Xtend2] class with empty method does not compile
Next Topic:Deploying my DSL to another Eclipse Environment
Current Time: Fri May 24 03:08:08 EDT 2013
Powered by FUDForum. Page generated in 0.03701 seconds
