Home » Modeling » Epsilon » How to integrate EGL with diagram
How to integrate EGL with diagram [message #674393] Thu, 26 May 2011 14:16 Go to next message
Paulo Del Aguila is currently offline Paulo Del Aguila
Hi guys,
I've done my egl code to generate code from a model, but I would like to integrate as the menu edit-> validation of EVL. Is there any way to call an EGL code for a button or menu to generate code?
Thank you in advance for your help.
Paulo Del Aguila
Re: How to integrate EGL with diagram [message #674427 is a reply to message #674393] Thu, 26 May 2011 17:31 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Paulo,
The following example demonstrates how Epsilon programs can be executed from Java http://eclipse.org/gmt/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.standalone (look for the EglStandaloneExample class)
You'll need to create the button, get hold of the EMF Resource that underpins the diagram in your GMF editor, wrap it as an InMemoryEmfModel and add this model to the model repository of the EglTemplateFactoryModuleAdapter before you execute it.
Dimitris
Re: How to integrate EGL with diagram [message #674484 is a reply to message #674427] Fri, 27 May 2011 02:19 Go to previous messageGo to next message
Thank you Dimitrios. I looked all the code, but still do not know how to integrate it into mymodel.diagram, sorry for the silly question.
Re: How to integrate EGL with diagram [message #674512 is a reply to message #674484] Fri, 27 May 2011 04:00 Go to previous messageGo to next message
Hi Paulo,
Is there any specific aspect of the code that you found difficult to understand/integrate?
Dimitris
Re: How to integrate EGL with diagram [message #674823 is a reply to message #674512] Sat, 28 May 2011 14:23 Go to previous messageGo to next message
Hi Dimitrios,
I have to put the two packages (epsilonstandalone and eglstandalone) in mymodel.diagram and in some part of my code call the postprocess method?
Thanks for the support again.
Cheers
Paulo Del Aguila
Re: How to integrate EGL with diagram [message #675239 is a reply to message #674823] Mon, 30 May 2011 17:26 Go to previous messageGo to next message
Hi Paulo,
I've added an example of doing this here: https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsilon/trunk/examples/org.eclipse.epsilon.eugenia.examples.friends.callegl
You'll need to check out all the org.eclipse.epsilon.eugenia.examples.friends.* projects to get this working. For instructions on how to check out code from the Epsilon SVN please refer to http://eclipse.org/gmt/epsilon/doc/articles/epsilon-source-svn/
Dimitris
Re: How to integrate EGL with diagram [message #683116 is a reply to message #675239] Sun, 12 June 2011 23:09 Go to previous message
Thanks a lot Dimitris. It works well. Surprised
Paulo Del Aguila
Previous Topic:[Flock]
Next Topic:[Eugenia] FixGMFGen and nullpointerexception
Current Time: Thu May 23 04:36:00 EDT 2013
Powered by FUDForum. Page generated in 0.01839 seconds
