Home » Modeling » UML2 » Should UML model be saved as EMF annotations in the java code ?
Should UML model be saved as EMF annotations in the java code ? [message #682867] Sun, 12 June 2011 06:01
Vlad Varnica is currently offline Vlad Varnica
There is today a dilema on how to save UML model information when dealing with Java.
Do you think that saving UML model such as EMF annotations in the java code is a good practice ?
I think that it is a mistake to mix both java and model information in the code because:
- adding annotations is changing the original code format. The code gets dirty
- if the code is refactored then model information could be lost.
If you need more information to contribute to the current discussion you can have a look at a good documentation that I found at: http://www.vogella.de/articles/EclipseEMF/article.html
Let me know your point of view and let's talk about it !!
[Updated on: Sun, 12 June 2011 06:06]
Report message to a moderator
Previous Topic:Should we immediately create inheritances at modeling stage ?
Next Topic:Can UML be agile if the code is not uploaded into the model ?
Current Time: Fri May 24 12:52:43 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
