Home » Eclipse Projects » XML Schema Definition (XSD) » mistake
mistake [message #677374] Wed, 08 June 2011 06:29 Go to next message
Julie  is currently offline Julie
No Message Body
[Updated on: Wed, 08 June 2011 06:33]
Report message to a moderator
Re: XMI parsing - creating a database [message #677472 is a reply to message #677374] Wed, 08 June 2011 11:49 Go to previous message
Ed Merks is currently offline Ed Merks
Have a look at Teneo and the next time you ask a question, try to
demonstrate you've done a bit of work and try to put a little more
effort in your question to make it sensible. I.e., you parse a file,
but want to load (not store?) the name of the class (what class?) in a
data base.
forums-noreply@eclipse.org wrote:
> Starting from an xml file, I want to parse this file and load the name
> of the class in a data base. Some one can help me please?
Previous Topic:xsd:string vs. xsd:NMTOKENS
Next Topic:creating XPATH 2.0 expressions while navigating schema
Current Time: Wed May 22 07:20:17 EDT 2013
Powered by FUDForum. Page generated in 0.01494 seconds
