Home » Eclipse Projects » Web Tools Project (WTP) » @XmlSchema for a metro webservice
@XmlSchema for a metro webservice [message #675979] Thu, 02 June 2011 05:07 Go to next message
Cristian Prevedello is currently offline Cristian Prevedello
i'm having problems to set qualified as elementFormDefault.
i'm using glassfish metro web service stack, with eclipse helios.
i've my own webservice class
WebService(name = "MyWebService" , targetNamespace = "myURL")
@BindingType(value="http:__java.sun.com/xml/ns/jaxws/2003/05/soap/bindings/HTTP/")
@SOAPBinding
style = SOAPBinding.Style.DOCUMENT,
use = SOAPBinding.Use.LITERAL,
parameterStyle = SOAPBinding.ParameterStyle.WRAPPED
public class MyWebService
To setup proper schema i added package-info.java to my package where my webservice is
@XmlSchema ( elementFormDefault=javax.xml.bind.annotation.XmlNsForm.QUALIFIED,
attributeFormDefault=javax.xml.bind.annotation.XmlNsForm.QUALIFIED,
namespace="myURL",
xmlns = {
@javax.xml.bind.annotation.XmlNs(prefix = "services", namespaceURI="myURL"),
package com.viewshape.webservices;
import javax.xml.bind.annotation.XmlSchema;
the package-info.class is deployed to glassfish but when i request the wsdl qualified is not set there.
thank you in advance.
Re: @XmlSchema for a metro webservice [message #676026 is a reply to message #675979] Thu, 02 June 2011 10:24 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
So how does the problem manifest itself?
The value "myURL" isn't a very good URL and
"http:__java.sun.com/xml/ns/jaxws/2003/05/soap/bindings/HTTP/" doesn't
look like a very good namespace either.
> @SOAPBinding
> ) public class MyWebService
Re: @XmlSchema for a metro webservice [message #676332 is a reply to message #676026] Fri, 03 June 2011 14:41 Go to previous message
since i just joined the forum, i can't post a message with url inside the message itself, so i had to replace the actual urls with other values.
in the source code the urls are valid http urls
Previous Topic:how to override addBreakpoint and deleteBreakpoint listener of javascript
Next Topic:New Editor?
Current Time: Sun May 19 21:05:09 EDT 2013
Powered by FUDForum. Page generated in 0.01669 seconds
