Home » Eclipse Projects » Web Tools Project (WTP) » Code completion for global defined in other files(How can I use code completion for global that are defined in other files)
Code completion for global defined in other files [message #674344] Thu, 26 May 2011 11:07 Go to next message
Missing name Missing name is currently offline Missing name Missing name
I'm attempting to use code completion on a property of a global namespace. I've defined & JSDoc'ed the global in another js file (which is included in the project, and I get that variable in code completion). When I try to use this property, I get no options for code completion. Is this possible to do?
File 1
var foo = {};
File 2
foo.prop = function(){return "Hello World";};
When I try to use code completion in File 2 to prompt for foo.prop, I see no proposals.
Re: Code completion for global defined in other files [message #675638 is a reply to message #674344] Wed, 01 June 2011 00:30 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
On 5/26/2011 11:07 AM, forums-noreply@eclipse.org wrote:
> Hello,
> File 1
> var foo = {};
> File 2
> see no proposals.
At the moment, no, not unless both files are open in editors. Proper
(and performant) support for Globals is something we want to visit in
the next maintenance release.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Web Service Problem with tomcat axis2
Next Topic:Problem with XMLMultiPageEditorPart editor
Current Time: Wed May 22 14:02:02 EDT 2013
Powered by FUDForum. Page generated in 0.01565 seconds
