| Install dialog hangs [message #675141] |
Mon, 30 May 2011 08:09  |
Marco Gerber Messages: 10 Registered: May 2011 |
Junior Member |
Hello everybody
While installing tptp 4.7.2 from [1], the installing software dialog is hanging while fetching download.php from [2]
How can I make the install run ?
I'm using SpringSource Tool Suite:
Version: 2.6.0.RELEASE
Build Id: 201103161000
[1] download.eclipse.org/tptp/updates/
[2] www.eclipse.org/downloads/download.php?file=/tptp/updateformant=xml&countrycode=us?timeZone=1&format=xml
Marco
| Re: Install dialog hangs [message #675174 is a reply to message #675154] |
Mon, 30 May 2011 09:52  |
Junior Member |
Hi Torsten
Yes, you're right. As a workaround for all of those who have the same problem, you can download the complete runtime package (without the required dependencies) from [1] (direct), or [2] (overview) and unpack it where your eclipse is installed. You may also try to install the required dependencies over eclipe's regular installation way.
Marco
[1] www.eclipse.org/downloads/download.php?file=/tptp/4.7.2/TPTP-4.7.2/tptp.runtime-TPTP-4.7.2.zip
[2] www.eclipse.org/tptp/home/downloads/
[Updated on: Mon, 30 May 2011 09:55] Report message to a moderator
FUDForum. Page generated in 0.02051 seconds
