Home » Eclipse Projects » ACTF » WCAG Guideline Errors - ("This page seems to have several HTML Elements")
WCAG Guideline Errors - [message #663293] Mon, 04 April 2011 10:49 Go to next message
John Chappell is currently offline John Chappell
I'm using adesigner to check a website I have developed and keep getting a compliance error "This page seems to have multiple HTML elements". The problem appears to be with the <html> declaration - see below
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
I've looked at the WCAG guidelines and cannot see anything wrong? The page also passes validation through the W3C validator so cannot figure out whats wrong?
Any ideas or help much appreciated
John Chappell
Re: WCAG Guideline Errors - [message #674354 is a reply to message #663293] Thu, 26 May 2011 11:31 Go to previous message
Kentarou Fukuda is currently offline Kentarou Fukuda
Member
Excuse me for this late reply.
In some cases, aDesigner report the error if the html file has BOM (byte order mark).
Would you please confirm it?
If the file has BOM, please remove it.
If not, and if possible, would you please attach a sample html?
I'll try to investigate it more.
Thanks.
Previous Topic:Cross-platform compatibility
Next Topic:eclipse help
Current Time: Sun May 19 16:21:58 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
