Home » Language IDEs » AJDT » Aspectj JoinPoint
Aspectj JoinPoint [message #674226] Thu, 26 May 2011 04:20 Go to next message
moha  is currently offline moha
Member
I want to define a pointcut in order to select joinpoint that is an execution of methods wich have the package name start with a defined string .
example : package.name.example1111.test.myMethod1(int a)
package.name.example2222.ttttttt.ddddddd.function(String s,boolean flag)
i tried :
@Pointcut("execution (* package.name.*.*(..)))
public void myPointcut() {
but it didn't work.
any idea ????
thanks in advance.
Re: Aspectj JoinPoint [message #674474 is a reply to message #674226] Fri, 27 May 2011 01:02 Go to previous message
Andrew Eisenberg is currently offline Andrew Eisenberg
Two possibilities:
1. I don't know if this is the actual package name that you are using, but 'package' is not allowed in a package name.
2. package.name.*.*(..) will match all methods in all types inside of the package package.name, but it will not match anything in package.name.foo. Instead, you need to do package.name..*.*(..) (notice the extra do).
Previous Topic:Problem to catch exception with aspectj
Next Topic:exclude <clinit> java in pointcut
Current Time: Thu May 23 13:15:37 EDT 2013
Powered by FUDForum. Page generated in 0.06063 seconds
