Home » Eclipse Projects » Eclipse 4 » Which Feature contains the Visual Design Editor for e4?
Which Feature contains the Visual Design Editor for e4? [message #674203] Thu, 26 May 2011 02:44 Go to next message
Christian Eugster is currently offline Christian Eugster
I have problems to install eclipse e4 (4.1 RC2) with the design tools on both windows xp and macos. Ich have downloaded and unzipped Eclipse 4.1 RC2. I tried several configurations but I have not succeeded to configure a working environment. I could not find any documentation about which tool I find in which feature. Is there any documentation about that or can anyone give me some hints?
About xwt: After having installed the xwt bundles, the ide freezes as I try to open the perspective or open an xwt file in the editor.
Christian
(no subject) [message #674209 is a reply to message #674203] Thu, 26 May 2011 02:48 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
I'm not sure which Visual Design Editor you are talking about:
* The XWT-Editor
* The Visual e4 Workbench Model Editor
The latter is discontinued and the first also never worked at least for
me. IIRC Window Builder which is now an Eclipse.org-Project has support
for XWT but you'd have to ask at their forum. Window Builder is known to
run on Eclipse 4.1.
Tom
Am 26.05.11 08:44, schrieb Christian Eugster:
> Thanks
> Christian
Re: (no subject) [message #674367 is a reply to message #674209] Thu, 26 May 2011 12:35 Go to previous messageGo to next message
Thank you for your rapid answer. How am I supposed to model the workbench model (xmi file), if the workbench modeller is discontinued. What alternatives exist?
Re: (no subject) [message #674371 is a reply to message #674209] Thu, 26 May 2011 12:43 Go to previous message
Sorry,
I found an answer by Paul Webster from two years ago! The workbenchmodel editor resides in the e4 tools feature.
Thank you
Previous Topic:Reseting the Window Layout
Next Topic:[ Databinding ] Error due to two ways of normalization
Current Time: Fri May 24 14:44:50 EDT 2013
Powered by FUDForum. Page generated in 0.01738 seconds
