Another ClassLoader Problem [message #671854] |
Thu, 19 May 2011 03:39  |
No real name Messages: 3 Registered: May 2011 |
Junior Member |
maybe you can help me.
I wanted to make a pipelet to extract text from a html page with XPath.
I´m using the DOMPArser class from Nekohtml, like you guys. But the class isn´t found at runtime.
I added the required line in the MF:
org.cyberneko.html.parsers;version="1.9.9",
In the log i get the following error then:
org.apache.ode.bpel.iapi.BpelEngineException: java.lang.RuntimeException: java.lang.NoClassDefFoundError: org/cyberneko/html/parsers/DOMParser
Caused by: java.lang.NoClassDefFoundError: org/cyberneko/html/parsers/DOMParser
I think thats only a follow up exception, the first exception i get is:
java.lang.NoClassDefFoundError: org/apache/xerces/parsers/DOMParser
I also included that in the "Import-Package" section of the MF:
org.apache.xerces.parsers;version="2.9.0",
I´m stuck, 2 hours i´m trying to figure out what the hell is wrong. I even tried to include the jars directly into my classpath. That didn´t work either.
Greets
Jan
[Updated on: Thu, 19 May 2011 03:45] Report message to a moderator
| Re: Another ClassLoader Problem [message #671903 is a reply to message #671854] |
Thu, 19 May 2011 06:05   |
Originally posted by:
Am 19.05.2011, 09:39 Uhr, schrieb No real name
<forums-noreply@eclipse.org>:
> I wanted to make a pipelet to extract text from a html page with XPath..
Actually, we do not use *this* parser, so we didn't notice that ...
.... this needs to be added to the MF of the org.cyberneko.html bundle.
At least, then I can create a dummy instance of DOMParser in the
HtmlToTextPipelet.
I committed the change to our trunk, please try if this is sufficient for
you or
if more imports are needed.
Jürgen.
| Re: Another ClassLoader Problem [message #671949 is a reply to message #671854] |
Thu, 19 May 2011 08:30   |
thomas menzel Messages: 81 Registered: July 2009 |
Member |
hi,
did u try to import all the stuff that we import in our SMILA Standard
Pipelets Plug-in ?
just looking at it we import
org.apache.xerces.xni;version="2.9.0",
org.apache.xerces.xni.parser;version="2.9.0",
note, the .xni. package part that u are missing below...
On 19.05.2011 09:39, No real name wrote:
> work either.
thomas menzel aka tom
FUDForum. Page generated in 0.01677 seconds
