Home » Eclipse Projects » scout » Access a Scout Service from another servlet
Access a Scout Service from another servlet [message #670772] Sun, 15 May 2011 09:16 Go to next message
Adrian Moser
Member
What is the easiest way to use Scout Services from another Non-Scout-Servlet, e.g. a GWT RemoteServiceServlet?
So far I figured out that I could create a subject and a server session and use a ServerJob:
	        Subject sub = new Subject();
	        sub.getPrincipals().add(new SimplePrincipal("admin"));
	        ServerSession s = SERVICES.getService(IServerSessionRegistryService.class).newServerSession(ServerSession.class, sub);
	        ServerJob test = new ServerJob("", s) {
	          protected IStatus runTransaction(IProgressMonitor monitor) throws Exception {
	        	  SERVICES.getService(I...Service.class)...();
	            return null;
	        test.setSubject(sub);
	        test.runNow(null);
Any ideas?
Kind regards,
Adrian
Re: Access a Scout Service from another servlet [message #670852 is a reply to message #670772] Sun, 15 May 2011 17:50 Go to previous message
Andreas Hoegger is currently offline Andreas Hoegger
1. Use services without a session:
If you do not need any session information (userId, username,...) you
can register global service.
<extension point="org.eclipse.scout.service.services">
<service
class=" bsiag.testapp.server.services.custom.test.ServiceWithoutSess ionService "
factory="org.eclipse.scout.service.DefaultServiceFactory"/ >
</extension>
Importend is to use the DefaultServiceFactory.
2. Use session based services:
In this case the solution is pretty similar you have done. Instead of
creating a new subject and session for every call you could create a
member on the Activator (e.g. get/setBackendSession) and create the
backend session once in the ServerApplication.start method.
ServerApplication
public Object start(IApplicationContext context) throws Exception {
ServerSession session =
SERVICES.getService(IServerSessionRegistryService.class).new ServerSession(ServerSession.class,
Activator.getDefault().getBackendSubject());
Activator.getDefault().setBackendSession(session);
logger.info("testapp server initialized");
return EXIT_OK;
Later instantiate the ServerJob with the backend session.
ServerJob job = new
ServerJob("",Activator.getDefault().getBackendSession()) {
-Andreas
> ServerSession s =
> sub);
> @Override
> return null;
> test.runNow(null);
> Any ideas?
> Kind regards,
> Adrian
Previous Topic:Recommendation Models for Scout?
Next Topic:Enable validation of keys typed in AbstractStringField
Current Time: Sun May 26 02:21:31 EDT 2013
Powered by FUDForum. Page generated in 0.01476 seconds
