| How to extend meta model via OCL? [message #670518] |
Sat, 14 May 2011 12:16  |
Kirsten M. Z. Messages: 106 Registered: July 2010 |
Hi @all,
could someone explain or post a link to a tutorial how to extend a meta model via OCL (without changing the meta model directly)?
I need M2T AND M2M in one of my projects. In both cases, I can call meta model functions (QVTo and Acceleo). Therefore, I add operations to the meta model whenever I need functionality in both transformations.
The sad thing: I can only add operations to my own meta model, but I want to add operations to UML::Element or UML::String as well. Of course, I don't want to touch the original UML meta model or recreate anything.
A collegue said that there should be a possibility to use OCL for that. Basically, inside QVTo and Acceleo code, this is possible as well. So it is an obvious question if this is a feature of OCL itself. Using the "context" for UML::Element (and body?) for adding an operation?
We haven't found an example and we have no idea where to embed such OCL definitions.
Thanks for help or comment!
Kirsten
[Updated on: Sat, 14 May 2011 12:17] Report message to a moderator
| (no subject) [message #670521 is a reply to message #670518] |
Sat, 14 May 2011 12:40   |
Ed Willink Messages: 3151 Registered: July 2009 |
Hi Kirsten
You need a Complete OCL document to complement your UML (meta-)model.
In the past this has been available via the Java API as described in
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. ocl.doc/references/overview/parsingDocuments.html.
If you check out the Indigo variant you'll find a couple of significant
typos fixed.
The Helios OCL Examples add-on provided a Complete OCL editor that
worked against Ecore meta-models.
The Indigo OCL Examples add-on significantly enhances this so that it
also works for UML meta-models.
My EclipseCon tutorial
http://www.eclipsecon.org/2011/sessions/?page=sessions&i d=2271 showed
how Complete OCL could be used to complement an Ecore meta-model
allowing use during Xtext validation. In principle, if you use the RC1
Indigo release, you just change the import *.ecore to import *.uml.
The Indigo release of Papyrus will probably use a similar OCL editor for
OCL editing within UML diagrams.
The interactive OCL support for UML is very hot off the press, so don't
expect it to be perfect in Indigo; it is examples quality; release
quality will be achieved only in Juno.
Ed Willink
On 14/05/2011 17:16, forums-noreply@eclipse.org wrote:
> Hi @all,
> extend a meta model via OCL?
> can use call meta model functions (QVTo and Acceleo).
> Kirsten
| Re: (no subject) [message #670927 is a reply to message #670924] |
Mon, 16 May 2011 04:53  |
Hi Kirsten
[please use a subject and give yourself a name.]
You are at/beyond the edge of what works with Complete OCL. Getting
Complete OCL fully working for UML is challenging. In principle with the
aid of OCL delegates, the functionmality could just drop into Acceleo or
QVTo, but it's never that simple.
If you are looking for a production ready solution; look elsewhere. I'm
not sure where since OCL tooling has been quite slow to evolve.
If you are prepared to share some pain in getting this working then this
will be beneficial to a variety of people.
Yes. Each tool has distinct standalone setups. For OCL you can look at
JUnit tests, or see what documentation I remember to enhance for Indigo.
On 16/05/2011 09:38, forums-noreply@eclipse.org wrote:
> Hello Ed,
> thanks for your response.
> Seems that CompleteOCL is exactly what I was looking for.
> However, I don't understand your slides completely
> regarding Acceleo and QVTo. I also have to admit that admit
> that I am not familiar with Xtext.
> So just a concrete question. How does Acceleo and QVTo work
> with such CompleteOCL *.ocl files? And also very important
> for me: what to do in code for standalone applications, so
> using this technology without Eclipse (I already saw that
> things need a registry available in Eclipse and stuff). It
> was not trivial (and it is not well documented) to get
> Acceleo and QVTo working in a standalone environment. I
> expect something bad with CompleteOCL as well ;)
> Best regards,
> Kirsten
FUDForum. Page generated in 0.01605 seconds
