| Re: how to change or newly set web root's source folder [message #670032 is a reply to message #669912] |
Thu, 12 May 2011 09:06  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
On 5/12/2011 12:01 AM, jared wrote:
> just in the following config file
> \.settings\org.eclipse.wst.common.component
> <wb-resource deploy-path="/" source-path="/WebContent"/>
> i want to change /WebContent to /myweb;
> who can tell me how to do this changing in GUI? :(
You should be able to Rename the folder and that change would be picked
up in the "org.eclipse.wst.common.component" file. You can check by
opening the project's Properties dialog and going to the Deployment
Assembly page. This page would be where you would add, change, and
remove folders if you wanted only to make changes to
"org.eclipse.wst.common.component".
Larry
FUDForum. Page generated in 0.06126 seconds
