Home » Eclipse Projects » BIRT » Joining on a multivalue string(Help needed joining datasets on a field with multiple values)
Joining on a multivalue string [message #669455] Tue, 10 May 2011 08:01
Kim   is currently offline Kim
Hi all,
I need a cool tip from one of you.
I have 2 datasets
dataset 1 contains some columns and a particular column of type string. In this field I have a number of keys like "key1,key2,key13" - another datset contains the desciption for these keys with a key column and a description.
Now I would like to join or somehow replace the key values with the descriptions in dataset 1. any ideas ?
[Updated on: Mon, 16 May 2011 02:31]
Report message to a moderator
Previous Topic:Trigger problem with BIRT 2.5.0
Next Topic:Double sided printing of multiple reports?
Current Time: Fri May 24 21:12:00 EDT 2013
Powered by FUDForum. Page generated in 0.06994 seconds
