Home » Eclipse Projects » scout » Scout & Swing LAF
Scout & Swing LAF [message #667610] Fri, 29 April 2011 18:10 Go to next message
Adrian Moser
Member
When I run Eclipse Scout with Swing, is there a way to modify or even hide the light-blue area between the menus and the main default windows?
The light-blue area remains the same, I tried running Scout with Nimbus, Aqua Look and Feels and others. Also, the AbstractOutlineViewButtons have always the same look and feel, not changing to the Java LAF.
Adrian
Re: Scout & Swing LAF [message #667990 is a reply to message #667610] Tue, 03 May 2011 05:03 Go to previous messageGo to next message
Claudio Guglielmo is currently offline Claudio Guglielmo
Member
Hi Adrian
Yes you can replace that bar with an own implementation or you can use the class LegacySwingScoutRootFrame which should look better with the default look and feels. But keep in mind it is legacy so it possibly will be removed sometime.
To replace the default bar you need to override a method in the class SwingApplication.
public class SwingEnvironment extends DefaultSwingEnvironment {
  public ISwingScoutRootFrame createRootComposite(Frame rootFrame, IDesktop desktop) {
    ISwingScoutRootFrame ui = new LegacySwingScoutRootFrame(this, rootFrame, desktop);
    decorate(desktop, ui);
    return ui;
I agree that the default bar does not look good with the java LAFs. Could you report a bug https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Scout&am p;format=guided? That would be great.
Hope that helps.
Claudio
Re: Scout & Swing LAF [message #669414 is a reply to message #667990] Tue, 10 May 2011 05:14 Go to previous message
Adrian Moser
Member
Thanks, the ticket is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=345184
Previous Topic:Logging in Scout Framework
Next Topic:Recommendation Models for Scout?
Current Time: Wed May 22 18:20:27 EDT 2013
Powered by FUDForum. Page generated in 0.01495 seconds
