Home » Eclipse Projects » Eclipse Platform » Deploy eclipse plugin (On different Platform and Eclipse version)
Deploy eclipse plugin [message #667226] Wed, 27 April 2011 10:24 Go to next message
Mikael Petterson is currently offline Mikael Petterson
When I am developing the plugin I want to make sure that the following is vaild for my plugin:
- It installs and runs on different platforms ( Linux/Solaris/Windows).
- That it installs and runs on 2-3 different versions of Eclipse ( java developer).
I need to automate this so you can run some kind of ant script when it is time for release.
Anyone with hints on how to go about testing this. Anyone with experience of this or who has the same problem ( then we can work together to solve it...).
br,
//mike
Re: Deploy eclipse plugin [message #667379 is a reply to message #667226] Thu, 28 April 2011 08:39 Go to previous message
Paul Webster is currently offline Paul Webster
You can write test plugins, and then modify the automated test scripts
to install and run your tests. By default the test scripts run a test
plugin (with a test.xml) in the version of eclipse you just built.
masterBuild.sh [1] runTests shows the setup for our tests. runtests [2]
actually unzips an eclipse to use as a base, and calls the tests, and
test.xml [3] defines how we install plugins into an eclipse and launch them.
Later,
PW
[1]
http://dev.eclipse.org/viewcvs/viewvc.cgi/e4/releng/org.ecli pse.e4.builder/scripts/masterBuild.sh?view=co
[2]
http://dev.eclipse.org/viewcvs/viewvc.cgi/e4/releng/org.ecli pse.e4.builder/builder/general/tests/runtests?view=co
[3]
http://dev.eclipse.org/viewcvs/viewvc.cgi/e4/releng/org.ecli pse.e4.builder/builder/general/tests/test.xml?view=co
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Add Drag And Drop support for Team Synchronize View ?
Next Topic:Mouse listener on tab item of a workbench part
Current Time: Tue May 21 11:54:29 EDT 2013
Powered by FUDForum. Page generated in 0.01477 seconds
