Home » Eclipse Projects » Linux Tools Project » Using encrypted partition
Using encrypted partition [message #667258] Wed, 27 April 2011 12:41 Go to next message
Philippe Krief is currently offline Philippe Krief
Hi All
Are you aware of any limitation in running an Eclipse client on a Linux Encrypted partitions?
Thanks a lot for your help
Kind regards
Philippe
Re: Using encrypted partition [message #667316 is a reply to message #667258] Wed, 27 April 2011 21:44 Go to previous messageGo to next message
Severin Gehwolf is currently offline Severin Gehwolf
Member
Hi Philippe,
This should be just fine. The encryption layer should be transparent for applications.
HTH,
Severin
Re: Using encrypted partition [message #667334 is a reply to message #667316] Thu, 28 April 2011 03:58 Go to previous message
Thanks a lot Severin for your quick reply.
I greatly appreciate.
Kind regards
Philippe
Previous Topic:pkg-config with depends projects
Next Topic:Problem with Oprofile Plugin using Consolehelper
Current Time: Mon May 20 07:53:52 EDT 2013
Powered by FUDForum. Page generated in 0.01932 seconds
